Question about Radio Communications
Programming cable Where could i get a programming cable for motorola gp328 handset and base set ?
  • Radio Commun... Master
  • 1,654 Answers
The photo of the GP328 resembles the HT750 offered in the USA. If they use the same programming cable/equipment you would need the AARKN4074 Programming Cable, which requires a RIB (radio interface box) RLN4008.
OR you can use the RIB-less cable RKN4075. There is also a cloning cable available, part number RKN4073.
All of the above are offered on the assumption the GP328 and HT750 radio take the same cables. You might check with your local Motorola dealer to be certain.
Posted on Jun 01, 2009
Motorola gp328 plus vhf diagram
It is best if you contact Motorola Solutions
http://www.motorolasolutions.com/support
Mark
Motorola Mobility Support
Aug 08, 2014 | Motorola Waris GP328 GP338 GP638 Plus...
How to do hard reset to factory default settings for motorola gp328/338 portable radios.
take a cps file from harddisk and overwrite radio. then password is gone
Jun 16, 2012 | Motorola Radio Communications
Communication Between the GP328 AND GP339
you need to know what band is every radio, if are for the same band, then can be programmed to the same frequency.
Jan 10, 2010 | Radio Communications
How to program a motorola gp328 vhf 2 way radio?
i have program kit and software i need program for emergency siren what i have to do
Jan 04, 2009 | Motorola Radio Communications
More channles
You would need to have the radio reprogrammed using Motorola proprietary software, which is available to authorized Motorola dealers. The cost of reprogramming is typically between $25 and $40 in US dollars. GP328 radios can be programmed to have between 1 and 16 channels.
Oct 06, 2008 | Motorola Radio Communications
Extended Handset
The phones have to have the same carrier frequency as the base set. The "out of range" display is because the frequencies are not matching. Check with the manufacturer (via website) and ask if your second handset can be programmed to a different base.
Nov 16, 2017 | Motorola Mobility SD4561 Cordless Phone
Base does not register with second Handset.
to register the extra handset it has to be exactly the same to be compatible with the base
if it is a slightly different model or older unit it probably will not register
Oct 14, 2017 | Motorola Mobility SD4561 Cordless Phone
Radio Communications Logo
241 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
