Nokia 6600 Cellular Phone
Problem for Nokia 6600
Nokia 6600 multimedia problem
By qayyum21 on Oct 23, 2007
when i open gallery, it hangs, bluetooth not working
making and receiving calls efficiently
wen open camera it dont store snaps , msg comes temporarly overloaded
Same Problem
Mar 05, 2009
-   6600 gallry not open,ido format the mobile-   Guest
Nov 19, 2008
-   nokia 6600 multimedia problem when i open gallery, it hangs, bluetooth not working making and receiving calls efficiently wen open camera it dont store snaps , msg comes temporarly overloaded -   Guest
Sep 23, 2008
-   when i open gallery, it hangs, bluetooth not working-   1988-2
Jul 11, 2008
-   Camera..... says........ Temporary overlad.
Galary Hangs....'opening file'
not able to open file manager
Please help -   Guest
Jul 05, 2008
-   in my phone keypad alpha mode is not working -   Guest
Best Solution
posted on Feb 22, 2008
Very Helpful)
dobhan
Rank: Guru
Rating: 90%, 166 votes
The problem of your unit is not easy,you need a qualified technician to open your unit coz the bluetooth module is defective you need to replace it,and prepare some amount for it.....
Was this helpful?
Yes
No
Solution #2
posted on Jan 28, 2008
Very Helpful)
the little j
Rank: Guru  Nokia Expert
Rating: 87%, 217 votes
have the bluetooth changed by a cellphone technician but it will cost you
Was this helpful?
Yes
No
Solution #3
posted on Jan 13, 2008
Very Helpful)
Sunny1985
Rating: 87%, 159 votes
u have to change ur B.T module to fix this prodlem
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Dec 01, 2007
Somewhat Helpful)
deepgeet
Rank: Apprentice
Rating: 81%, 4 votes
when i insert the memory card my phone can not open the menu
Was this helpful?
Yes
No
Solution #5
posted on Mar 17, 2008
Somewhat Helpful)
amar01
Rank: Apprentice
Rating: 70%, 1 votes
try o close all opened application on your phone! maybe some large application are open! try hold press the MENU key! then the open apps will be seen in the left side of your phone!
Was this helpful?
Yes
No
Solution #6
posted on Oct 23, 2007
Not Helpful)
gizmo1
Rank: Wiz  Nokia Expert
Rating: 80%, 686 votes
ur memory in handset is going to over and number of application r loaded in it....remove that one and restore ur handset and try........issue with bluetooth of ur handset might arise.....
Was this helpful?
Yes
No
Solution #7
posted on May 03, 2009
Not Rated)
teroc
Rank: Master
Rating: 91%, 14 votes
Hi Friends,
Having problem with Nokia 6600? Don't Worry. There is a site where you can easily fix your problem.
Mainly Nokia 6600 problem is for Unlock CodePuk Code and other Lock Codes. If you are searching for such codes you Must Click Here.
There are also some problem with Nokia 6600. Such as software problemhardware problem etc. If you having these problem you can Click Here. May you find your solution.
Was this helpful?
Yes
No
Solution #8
posted on Apr 27, 2009
Not Rated)
ollil
Rank: Master
Rating: 97%, 15 votes
FIND YOUR SOLUTION FROM NOKIA.
HERE IS YOUR SOLUTION
www.nokia.com/6600/prob234ei32/solution
Thanks
Was this helpful?
Yes
No
Solution #9
posted on Mar 15, 2008
Not Rated)
dheeraj_64
Rating: 86%, 76 votes
The problem of your unit is not easy,you need a qualified technician to open your unit coz the bluetooth module is defective you need to replace it,and prepare some amount for it.....go to nokia care for repair
Was this helpful?
Yes
No
Solution #10
Not Rated)
navpha
Rank: Apprentice
Rating: 0%, 0 votes
The Problem is due to the handsets four IC (4 IC arranged it L shape) module which are not properly connected to handset board. A temp solution to open the handset and place some support on the top of IC's. So that their points are touch to the board.
This problem offen arraised on new Nokia 6600 handset since their IC's are connected to board by liquid Solder.
Was this helpful?
Yes
No
Solution #11
posted on Jan 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
change the BT module at the back of the phone
Popular Solutions for Nokia 6600 Cellular Phone
Questions and Unsolved Problems for Nokia 6600 Cellular Phone
Do you recommend Nokia 6600?
Answer
Answer
i have a htc smart phone and i put a password on it and forgot it
Answer
ATT Nokia 6085. Power up seems ok, sounds etc. Except screen is washed out white/blue. Close ****... (More)
Answer
my IMEI code is 357952009223323. What is the code for 3d motoracing for me?
20 Other Users Have The Same Problem - Continued
Comment by garima1616, posted on Jul 04, 2008
cannot take snaps...prompts temporary overload
cannot open gallery...
Comment by Guest, posted on Jun 08, 2008
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow. Any soluutions?
Comment by Guest, posted on Jun 05, 2008
Comment by lopbiz, posted on Apr 30, 2008
I am having nokia 6600 in which the file manager, gallery and blue tooth is not working. I have also formatted my phone by using the #,3 and the call key, but no use. Even i've also used *#7370# nothing. what can be the problem? Pla give me remedy. or contact me in lopbiz@gmail.com
Comment by Guest, posted on Apr 03, 2008
wen open camera
Comment by Guest, posted on Apr 01, 2008
Comment by Guest, posted on Mar 24, 2008
Comment by vineet_swami, posted on Feb 24, 2008
my bluetooth dosent work all multimesia options didn't open pls help
Comment by karto, posted on Feb 21, 2008
hey i formatted my phone memory by using green+*+3.but also gallery not opening bluetooth not functioning.i have no memory card..wat i can do now.
Comment by jt85, posted on Jan 07, 2008
My phone has the exact same problem. Bluetooth is not working, Hangs on gallery and when you try to take photos it just says Temporary Overload. Continue? It does this whether the memory card is inserted or not.
Comment by rkumar82, posted on Dec 16, 2007
making when open camera it don't store snaps , message comes "temporarly overloaded"
Comment by Guest, posted on Dec 01, 2007
gallery was not able to open, and when i use the camera temporarily overload!
Comment by deprosys, posted on Nov 20, 2007
gallery is not opening and bluetooth is not working
how to solve my 6600 set ,
Comment by Guest, posted on Nov 13, 2007
Blue tooth not working. Phone hangs when you open gallery. All applications removed and nothing is open but still problem exists.
Comment by Guest, posted on Nov 06, 2007
I read the solution it isn't working.
My nokia 6600 gets hang when i try to open gallery applications.
please help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia 6600 Cellular Phone:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 912
Experience: Having problems myself and learning from my mistakes . Plus looking up information on the web.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
