Question about Garden
The starter rope broke and I need to know how to reinstall it
How to repair the starter rope on the Poulan PPB150e weedeater?
  • 77 Answers
SOURCE: I have a Poulan Pro link trimmer PPB225E. The rope
It sounds like when it was assymbled that the cord wasnt routed through the holes of the plastic disk right to avoid it being pulled out. If you attempt to fix it yourself its no easy task,the entire casing needs unbolted and seperated. You need to make sure you DONT pull the recoil bands out,and there is a proper procedure of the cord routing and tying.This is a pretty advance repaire for a novice.
Posted on Aug 09, 2009
canbruce75
  • 1776 Answers
SOURCE: I need to change the pull rope on my poulan pole saw 446t
Check out the video at the link I am providing and see if it is what you're looking for. Sure hope so and best wishes.
http://www.youtube.com/watch?v=Zs91D_wln2Q
Posted on Sep 01, 2009
  • 279 Answers
SOURCE: pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Posted on Sep 04, 2009
bbreton
  • 437 Answers
SOURCE: Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Posted on Sep 29, 2009
Testimonial: "read suggetions & took another look. Found a small flat blade screw driver would work. Appreciate the help"
  • 8 Answers
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Posted on Apr 27, 2010
How do I change out the pull rope on Poulan 42cc chainsaw
I have found that youtube is a great place for chainsaw repair videos.
Check this one and see if it helps. http://www.youtube.com/watch?v=PsJ0sygoVBQ
Oct 20, 2014 | Poulan Garden
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
How to get the spring & starter rope back together on a weedeater featherlight leaf blower. model #FL1500LE
easiest is to take a slotted screwdriver, poke into the underside air intake and rotate the wheel a bit...usually the rope goes right back in...if not take the three screws out and release the rope.....while your there give it a few twists to loosen it up....you will do this soon enough when the rope breaks :)
GG
Nov 05, 2009 | Poulan Featherlite Gas Blower, with Low...
Poulan rope broke and pulled out of unit. How is
I have manually fixed these starters before and it is really more trouble than it is worth (and not one unit I fixed ever worked exactly the same afterwards). I would suggest taking it to your local small engine repair shop. They have both the patience and the tools to do the job right and the cost is well worth it--trust me!
Oct 20, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Sep 29, 2009 | Poulan Garden
Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
May 23, 2009 | Garden
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
