Question about Edirol UA-25 External Sound System
UA-25 V2.0 Drivers won't install to Windows XP laptop
I tried to install the supplied drivers supplied on the disc to no avail. It kept going around  in circles requesting that I connect after I adjusted the control panel and then disconnect it after a error message alert  states that I disconnect it and try again. I assumed this must be an issue with the various service packs and security updates by Microsoft.
Since I've tried to install the latest downloaded version 2.0 from the Roland website. I've installed it as per before, but I get a prompt saying that I've already installed or have similar drivers installed. Also states that I should un-install the existing drivers. Would this be referring to the existing drivers installed by the manufacturer of the laptop (e.g. Sound MAX)?
  • 14 Answers
SOURCE: Problem with stability
Celeron CPU's will struggle with making music and limit what you can do with audio. Celerons are ok to play music but nor really for making music. Firewire is a better option for making music as it's really fast unlike USB. An option would be to get a faster CPU and try the soundcard again. But i would not use USB audio and would use an Audiophile 2496 soundcard as they are really cheap. Also midi is data and not audio, midi just works virtual instruments and is able to control keyboards through midi out. But first try a better CPU as a celeron isant that good for makign music. I know becouse i've been there done that and go really upset with the same problems your having at the moment. I played the midi files on cuabse and recorded it onto an audio chanel.
Posted on Apr 13, 2007
  • 6 Answers
SOURCE: no sound driver
Most probably yes. Do you know the model number or the manufacturer of your sound card? if yes, then please check it up on the manufacturer's website first. Otherwise do a google search.
Hope this helps.
Posted on Nov 20, 2007
  • 105 Answers
SOURCE: I have a problem with my compaq laptop.
follow the link and downlaod the driver before that you may need to register your name for free
Posted on Jul 07, 2008
  • 1550 Answers
SOURCE: Can get signal from UA-25 to computer... but no audio from computer to UA-25?
Here is one solution uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Thanks for using Fixya
Posted on Sep 29, 2008
SOURCE: i cant find drivers for my pci bus and video controller (vga compatible)
driversRealtek ALC260 @ Intel 82801GB ICH7
Posted on Nov 09, 2008
Ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Aug 31, 2012 | Edirol UA-101 External Sound System
Sep 29, 2008 | Edirol UA-25 External Sound System
I have acer laptop aspire 5736z with windows 7 but i wanted to change the windows xp but it brings the error message (blue screen). it stops installing windows xp. what could be the problem. it boots well...
The problem is your computer uses a SATA hard drive and windows XP doesn't naitively support SATA. You have three options around this.
  1. Go into BIOS and if you have disable SATA/AHCI and set it to SATA/IDE emulation mode
  2. Download nlite and download sata drivers from intel's website and build your own windows XP disc and incorporate the sata drivers into it. Then use this disc to install.
  3. Download VirtualBox and install XP in a virtual machine to run on top of Windows 7
Windows XP will go end-of-life in 2014 and then Microsoft will no longer make software that is compatible FYI.
Comment if you need any additional assistance.
Sep 18, 2011 | Acer Computers & Internet
Need a recovery disc! i recently bought one with a completely erased hard drive. i have xp software and key dut need to recover disc prior to loading. any help?
If HP/Compaq cannot supply you with a recovery disc, then you can get around this.
Install Windows XP then download the device drivers for your model laptop and install them on your laptop. You can use a another computer with Internet access then copy and install them on your laptop.
Normal 0
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
Oct 09, 2010 | HP Compaq Presario C304NR Notebook
Every time i try to play any sound through my external sound card Edirol UA 25 my computer reboots it self for no reason. Any one knows why is that happening? my laptop is Advent 9115 and i have...
first try reinstalling the driver of your external audio device, but first uninstall it.
Also check the device itself it may have faults like shorts and the like causing the laptop o protect and restart.
Jul 02, 2010 | Edirol UA-25 External Sound System
Video Adapter for ati xpress 200m
Toshiba don't do drivers for XP. The ATI website states the following
The display driver supplied by the laptop manufacturer is customized for the built-in flat panel display, and the graphics features and functions specific to the laptop. It is strongly recommended to use the supplied drivers.
If installing a different operating system other than the one included with the laptop, the laptop may not meet all the requirements, and supported drivers may not be available.
The laptop manufacturer is the exclusive provider of driver updates. If the required driver update is not available at the laptop manufacturers’ website, it is recommended to contact the manufacturer directly, to see if an updated driver will be made available in the future.
AMD cannot provide driver updates directly from
Dec 22, 2009 | Toshiba Satellite A135-S2246 Notebook
I want to install Windows XP in CQ40-317TU so want drivers for the same.
few ways you can go around this.
contact manufacturer via website and download drivers for system for xp
go through each hardware on your system and go to their website and download drivers for each hardware for xp
install xp and do all updates and let windows find drivers and drivers not installed you can search afterwards
if you download any of them install them on disc so you dont loose them.
good luck and pleasae don't forget to rank this. If I can be any other assistance please let me know. Have a wonderfull day.
Mar 28, 2009 | Compaq Computers & Internet
Unless you're installing the software on Mac OS9, or Windows 2000 or earlier, the original installation disc isn't going to do you any good. Drivers are available here for Windows XP and earlier and Mac OS9 (there are no drivers available for Mac OS X). Be sure and read all notes (when you click on a driver download link), and get the upgrades for Windows 2000 or Windows XP SP2 if you're installing on either of these systems. Good luck!
Nov 10, 2008 | Canon Office Equipment & Supplies
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Edirol UA-25 External Sound System Logo
61 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
