Need to know how to get into settings, etc. on the vcr without having the original remote? Unfortunately there are no buttons on the outside to do this. There is an easy set up button but then nothi
Bought a used sony vcr model slv679hf, plays tapes great but I need to get into the settings so that I can set it up to record of the television.
  • 87 Answers
Go to:
http://www.devicemanuals.com/guide/VCR/Sony/Sony-VCR-VHS-SLV679HF-User-Guide-TXpRM05qTT.html
Posted on May 31, 2009
I need to know what button is set
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 22, 2012 | One For All URC-3021 Remote Control
My tv doesn't have a remote, and the color/contrast is off, but I don't know how to adjust this without a remote. Can anyone help me? The buttons on the front don't have a "Menu" so it doesn't...
Some tv can't go into the tv menu without the remote,all colors/contrast functions setting are in the menu setting.Try website like Remotes.com to buy an original remote or very close to it.
Feb 09, 2011 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
Have a Sharp VC-H810 vcr without remote. Is there a way tosiP, SP etc without a remote on the vcr? Thanks in advance!
Unfortunately if there is no menu option to do that or button on the VCR you will need one of these remote controls
http://www.replacementremotes.com/SHARP/Buy-RRMCG1236AJSB-VCR-Remote-Control.html
or
http://www.replacementremotes.com/SHARP/Buy-RRMCU0002AJZZ-Remote-Control.html
Jan 07, 2011 | Sharp VC-H810U VHS VCR
How do I set the recording speeds on the vcr without a remote control?
Unfortunately, you need the remote control to do this. You can get a replacement remote with all of the features here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12937528570080&smodel=VRDVD4001&brand_pn=SANSUI_VRDVD4001 . There are a couple of other versions of the Sansui VRDVD4001 and their remotes are also available from remotes.com. Search on the model but not the brand name.
Even the timed recording menu which doesn't need the speed button doesn't have a button on the front panel of the unit.
I wish that I had better news.
Dec 30, 2010 | Sansui VRDVD4001 DVD Player/VCR
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
Remote won't communicate with television
The sensor for these Panasonic tvs along with certain Toshiba models tend to have the problem with the sets sensor going out. But if you are using a universal remote because you do not have the original, then most likely you will need to use the vcr control codes to program the tv. but if the original doesnt work either. your insticts are probably right. There is one last trick if you do have the original remote that u can try. I've had this work for me several times on service calls. With the batteries removed. Press every single button on the remote once. make sure you do this nice and slow making sure you are pressing the button down . if its a toggle button or rocker button like most volume or channel up down buttons(meanning that physically the is one button but depending on what part of button you press it does something differemt) well treat these as seperate buttons. Also if the remote has any switches on it. Like vcr/tv switch or vcr 1 vcr 2 etc. Then switch to other position and repeat the process of pressing all buttons once again. (remote does not have too be pointed at tv for obvious reasons) Now replace the batteries and have fingers crossed. Good luck.
Mar 11, 2009 | Panasonic AG-520G 20" TV/VCR
Orion VR213
Call the number on the unit to price an original remote.
Jul 23, 2008 | Orion VR213 VHS VCR
Teaching a Universal remote w/o the original
use the menu button on the tv. you dont need the remote.
Dec 05, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Change recording speed
The only solution to this problem is to buy a new remote from the manufacturer. Aftermarket remotes that I have looked at: RCA, PHILLIPS, SONY, etc do not have a speed select button for the VCR. (which IMHO is stupid) Come on aftermarket people- it cant be that hard to program a speed select button!
Oct 13, 2007 | Emerson EWV603 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
