Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
AKAI PT5598HDI 55 Where is fuse located
ILL TURN ON THE POWER AND I GET SOUND BUT NO PICTURE, CAN ANYONE HELP WITH THIS? Where is the fuse located
    Scholar:
  • 70 Answers
This problem is beyond a blown fuse most likely. The fuses for the unit are located on the circuit boards and the back will need to be removed to access them. This problem could be due to a missing voltage that is used to turn on the picture section of the electronics. I would search for a used unit on ebay or parts on ebay and swap out the boards. The board swap is not too complex but voltages are dangerous within the set and service by a qualified electronics technician is recommended on this unit. Thanks and good luck. Dan
Posted on May 31, 2009
No picture but I have sound.
U have not change the projection bulb for this tv at lest 2 years,and u used the tv alots?The first thing u require to do is to change the projection bulb.See what happen,than go from there.
Apr 24, 2010 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
AKAI PT5598HDI Colors out of line and picture is bowed in on bottom and top.
http://www.fixya.com/support/t1663670-akai_samsung_pt4299hd_convergence Adjust the convergence manually. It's a pain and takes alot of patience. The diagram for the remote buttons helps a lot. If it won't adjust you'll have to replace a part inside the tv. Good luck! Hopefully it'll adjust.
Jun 14, 2009 | Akai PT5598HD 55" Rear Projection...
I have a 55 inch Akai rear projection tv.When I turnit on,the red timer light blink,and that is all.I've heard about this problem on here before.No pic and no sound
on the main board of the tv there is a fuse located if that is faulty this can happen,there are also many other possibilities but check out the fuse first many a times replacing the fuse solves the problem as its very negligible to replace the fuse the cost of fuse is under $1.
Mar 03, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
PT5598HDI Wiring Problem
the red wire will go somewhere to the right side near the High Voltage section. The green wire is probably antenna. DO NOT get them crossed...
Question. what connector if any is attached? The board will usually have a pin sticking up that is marked...
Jul 13, 2008 | Akai PT5598HD 55" Rear Projection...
PT5598HDI
More likely Icz103 & Icz104 the convergence amps. Are they heating at all?
Bill
Apr 25, 2008 | Akai PTH5498 54" Rear Projection...
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
500 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
