Fujitsu Siemens AMILO D-7830  PC Notebook
Problem for Fujitsu Siemens AMILO D-7830 (FSP:810U60145) PC Notebook
External monitor on Laptop not receiving a signal
By cathy486 on May 31, 2009
I have a older Fujitsu Lifebook with a broken screen, which I have been using with an external CRT and external keyboard. I recently upgraded the monitor on my desktop, and decided to move the Dell 19" flatscreen over to the Lifebook as its external monitor, and dump the old CRT. I hooked up the Dell, booted the Lifebook, and the XP Home (SP2) splashscreen came up on the Dell, showing XP loading. As soon as XP completed bootup, the Dell went blank, indicating zero input from the computer.After trying several different things, I hooked the old CRT back up, and it too went to black after the XP splash screen. I have tried replacing the cords, power supply, etc etc, but the only output I get to an external monitor is the XP spash screen, then nada. If this is a failed video card, why do I still see the splash screen?
Thanks for any help!
Cathy Harper
Comments:
May 31, 2009
- Actually no, I thought maybe the Lifebook already had a driver for it. When the new monitor didn't wotk initially, I thought it might be a driver prob., so I put the old CRT (which had been working beautifully) back on the system, but now it has the same problem as the new monitor. So now I have no monitor at all to use to install a driver!
Cathy
May 31, 2009
- Ok, couldn't actually find the disk for the monitor, so I went to Dell's support site and found the driver for that monitor. Went back to the laptop, went into VGA mode as you suggested, went to control panel->display->settings->advanced and installed the new driver. Guess what...NO CHANGE! Even though the system sees (apparently) the correct driver, it remain in the lowest VGA settings, and any attempt to change them results in the display shutting off.
Clarification Request
Posted by CompuFirm on May 31, 2009
Have you installed the software/driver for the new mointor before installing the monitor?
Solution #1
posted on May 31, 2009
Not Rated)
CompuFirm
Rank: Wiz
Rating: 83%, 59 votes
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens AMILO D-7830
Questions and Unsolved Problems for Fujitsu Siemens AMILO D-7830
Do you recommend Fujitsu Siemens AMILO D-7830 (FSP:810U60145) PC Notebook?
Answer
Answer
My LG 405 has the following problem of display 1. (separation of 4 box in the screen with no... (More)
Answer
Whilst typing on screen the cursor drops to the bottom of the page at random - has anybody any idea... (More)
Answer
problem: solfware not found. on my fujetso laptop computer.how to solve this?
Answer
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non... (More)
Answer
thanks -i will try the information you gave me-the screen also stays black-but when i remove the... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
