Question about Chicco Ct0.6 Topazio Stroller
Can't clean the fabric on the stroller
I don't know whether to try to unscrew the fabric/seat or just try to spot treat my stroller. It looks terrible and needs to be cleaned. Thanks!
  • necoleray Jun 01, 2009
    Thank you so much! I will!
I took mine off completely like 10 mins to take off and 45 mins to put back on but mine looks great now!! Throw it in the washer on cold delicate then air dry. Does NO damage to the fabric.
Posted on Jun 01, 2009
I have a quinny buzz xl but not sure I own correct raincover does anyone know if they have their own specific one?? It fit my infant seat fine!
Hi
The same raincover fits the Quinny Buzz regardless of whether the infant stage or 2nd stage seat fabric is on the chassis.
Jun 02, 2012 | Quinny Baby Gear
How do i attatch the quinny zapp xtra seat to the quinny zapp frame
Yes the new seat unit can be used with old zap.You remove the fabric seat (look on u-tube if you don't know how)the new seat unit then fits on to frame via the addapters that come with the xtra seat unit, at the point where the car seat addapters fit.There is a large push button on the top of the seat unit which you push in to recline or sit up the seat, and a little one too next to it, that needs to be pushed away from the larger one, while you hold the large button down when you want to remove the seat unit.I found fitting the xtra seat very easy.To fold the zapp you Must remove the entire seat unit as it won't fold with it on, unlike the old one.
Nov 30, 2011 | Quinny ZAPP Stroller
Hello i have a quinny buzz 3 and will like to wash the seat. dont know if i should put it in a washing machine pls.
Good Morning
Spot cleaning should be done by mixing warm water with a mild handwash detergent and using a clean sponge on the fabric taking care not to make it too wet as this may cause water marks.
If you really want to wash the whole fabric you can do so; Remove it from the sub seat (seat frame) to wash. Handwash is best, but if you have a handwash or delicate cycle on your washing machine this may be used. Maximum temperature 30 degrees, using a mild detergent and if possible do an extra spin following washing to make sure most water is out of the fabric. Then to dry don't put it in a tumble drier as this can cause mis-shaping, instead leave to dry naturally (not in direct sunlight as this can cause discolouration) and make sure fabric is fully dry before putting back onto unit for use as damp areas can cause mould or mildew growth.
Jul 24, 2011 | Quinny Buzz Three Wheel Stroller
Cleaning fabric
contact www.buggypitstop.co.uk they service and clean pushchairs
Jan 08, 2010 | Bugaboo Frog - Black Stroller
How to take covers off Quinny Freestlyle XL 3 stroller for cleaning
I have been advised that the fabrics for the Quinny Freestyle XL3 can be removed. They seem to be stitched, but the very last part is on a D-ring shape piece of metal if you move the fabric to one side you will see a gap in the D-ring and then you can slide or manoeuvre the fabric out of this.
Sep 29, 2008 | Quinny Freestyle 3 XL Stroller
Removing the seat cover to wash
What I did is cut the hole about .5cm bigger (to fit buckel thru) and then resowed it by hand with a strong thread. I would not recomend washing it in a top load machine (it damaged our seat) best would prob. be dry clean.
Aug 02, 2008 | Zooper Jazz Jogger
Stroller pad cleaning
You can remove the seat pad by unsnapping the two straps on either side of the bottom of the pad (where it covers over the metal frame). Then just thread the buckles through it. As far as the rest of the fabric such as canopy or fabrice sides, no luck. I got this stroller used and wanted to wash it all. I ended up just putting it (minus the removable pad) into my shower and washing it with the shower head. Then I got a Mr. Clean magic eraser and cleaned up the plastic parts. Now it looks so good!
Hope this helps...
Jan 03, 2008 | Evenflo Aura Traditions Travel System...
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Clean fabric on stroller
I have just removed mine and hand washed it, but left the rain hood/pocket section in place and wiped that part clean to avoid unscrewing it
Apr 11, 2007 | Maclaren Techno XT Wisteria Umbrella...
Chicco Ct0.6 Topazio Stroller Logo
486 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
thegtw
Shehu Pro
Shehu Pro
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
