Question about Metz 70 MZ-5 TTL Flash
Metz 45 ct5 flash battery pack wiring diagram
I changed the nicad batteriesĀ  in my Metz 45 battery pack, but I cannot figure out how the wiring is hooked up. Can anyone help?
  • Anonymous Mar 12, 2014
    metz 45 CL4 DIgital will not charge
    Champion:
    Scholar:
  • 216 Answers
You can rig that fella up for a better power.
atdlee@netzero.com
Posted on Dec 30, 2007
Metz CT-4 flash gun overheated on the shaft the plastic casing overheated and melted the plastic on the handle grip I opened it up and noticed the wires inside were completely Melted.
Unfortunately, from your description, the flash is completely done for - while a repair may be possible, I doubt if it would be economically worthwhile. Replacement is probably the only answer.
What may be more important is to find out why this occurred - is it down to the charger, the batteries or an internal problem with the flash ? Were the batteries those supplied by Metz, or a different make ? If they were Metz ones, then maybe you should inform the manufacturers, to help others avoid this problem, and you might get a replacement flash if it is a manufacturing problem.
Jan 13, 2016 | Metz Cameras
Pinouts for metz 45-ct5 flash
Center of PC Sync Plug is Positive.
Outside is ground,
atdlee@netzero.com
Feb 10, 2014 | Metz Mecablitz 60CT4 TTL Flash
Where can I get battery power pack(shell with recharchable batteries inside) for metz 45 cl series,good second hand,off market brand,or even geniune brand,thank you
I have a lot of old 45-40 Series Metz 45 NiCd battery packs, that I will eventually rebuild with new NiCd batteries. I got them from Photographic Trader magazine and from ebay. I've heard that NiCd cells are going out of production, in favour of NiMH cells. I've found it's easier to put NiCd or NiMH cells in the alkaline battery holder, the flash recycle time is only slightly longer. I charge them separately out of the holder, or in the holder with a connector I made. NiMH cells need a suitable charger, with peak detection, as NiMH cells don't like being overcharged.
Nov 05, 2010 | Metz mecablitz 45 CL-4 TTL Flash
Changing rechargeable battries 45-40
Metz 45-40 consist of 6 nos of NiCd - AA size batteries connected in series. These battery packs can be rechanged by resoldering new set of AA size rechargable Nicd battries. Care should be taken not to short circuit the cells when disassembling and assembling the cells. Keep a note (sketch) of the connections of the cells, specially the longer connecting metal strip and the polarities of cells. re-solder the new set of AA size NiCd Batteries. If the old wires were corroded, use new wires' If the connecting terminals also corroded' clean it. If it is severely corroded, get it plated prior to fixing for better performance.. There is an charging indicating lamp which also control the charging current of the batteries. check its connections and solder it if required. I wish you got the answer for your problem.
H.D. Shirantha.
Sep 07, 2010 | Metz 45 CL-1 Flash
What batteries do i need to put in metz 45 battery hplder
AA Size Alkaline manganese batteries better for 45 Battery Holder.
H.D.Shirantha
Aug 21, 2010 | Metz 45 CL-1 Flash
How long does it take to charge metz 45-50 battery
it will take 4 to5 hr to charge the neon will be bright when the battery are weak the neon will be Dim when the battery are charge
Oct 27, 2009 | Metz 45 CL-1 Flash
How to disassemble metz battery pack
Cleaning is unlikely to cure your problem.
To change the cells follow these instructions, taking care not to short circuit any of the cells.
You need to know how to use a soldering Iron.
You need to understand basic electrical principals.
Stand the battery on the part with the charge socket at the bottom, the plastic at the top is held in place by a series of plastic latches.
Look closely to see them.
Release these latches CAREFULLY one by one with awatchmakers screwdriver, until the cover can be removed.
This will enable you to see a single, roughly central crosshead screw.
Remove this screw.
Unsolder the contacts at the top.
Separate the top and bottom parts gently, whilst feeding the now unsoldered wires into the assembly until you can see the lower soldered contacts on the cell units.
Unsolder these two contacts, and separate the top and bottom parts completely.
Withdraw the six cell units together, and hol them together with an elastic band.examine closely and note the long metal strip which is required to pass over a seperator in the housing.
Note also the transparent rings around the positive contacts on the cells, recover an re use these.
Purchase either solder tagged NiCads and solder them yourself, or get a battery supplier to replicate the complete six cell unit. (30 bucks here in France).
DO NOT try to solder cells without solder tags. Battery replacement stores are equipped with micro spot welding equipment to connect these.
In either case it is MUCH easier to reassemble the battery pack using the upper housing to keep the cells in place whilst soldering or welding.
Rebuild the unit.
Done!
Mar 20, 2009 | Cameras
Metz 45 CT5 Instruction manual download
Hi!
Try this link. It is to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will solve your problem
kind regards
Lars
Feb 18, 2009 | Metz mecablitz 45 CL-4 TTL Flash
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
NiCad battery not charging
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Oct 23, 2007 | Metz 60CT-1 Flash
Metz 70 MZ-5 TTL Flash Logo
1,358 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
