Question about Sanyo DS31520 31" TV
Input key quit working on my remote
The "input" key quit working on my remote. Is there any other way to get to the video channel? As it stands I cannot watch DVD's.
    Scholar:
  • 70 Answers
Some tv's will scroll into the video channel's with a channel up and down so like from channel 0 to video 1 and then to channel 99. you may have to program the video channel into the list with the channel add/delete function. I would check ebay or remotes.com for a replacemnt. In some cases the remote can be opened and the button that is not working can be cleaned and restored to working condition. In most cases there is one screw andthe remote snap fit's together. So try a universal first and the n look into oem replacement options.
Posted on May 31, 2009
I have a really old sanyo tv. The roommate brought it with a universal remote, which will not work with the TV, and I also bought another universal remote that will not work either. I just want to get to...
Sanyo sets, especially the old ones are like this, if no button on set the only thing you might try is run one channel at a time below channel 2 to see if one of the upper channels is the video input, other than that you are done.
Dec 14, 2012 | Televison & Video
My Old 1997 GE 31GT660 was working just fine yesterday with a PS2. My girlfriend moved it today while cleaning and now I cannot get the PS2 to work. We have no remote but a friend used a universal to get...
Ur girl friend clean around did she unplug the tv.Replug it back later?Bet u she did,that why the tv universal codes is gone.Reprogram ur tv unverisal codes again should solved this problems.Tries push the manual control button channel up like one or two times tv will be in input video again like video 1 or 2.
Jan 13, 2011 | GE 31GT660 TV
I have lost the orignal remote for my tv and have a universal remote. I get the tv/video button to work. is there some way to change it with out using the remote?
Unfortunately, the Input button (to change the source from INPUT 1, INPUT 2,
INPUT 3, INPUT 4, Front Input, HDMI/DVI, and last-active channel) is only on the remote. If your universal remote was built 6 months after the TV was released, try a different code for RCA/Thomson TVs (assuming the remote has an input or source key). Thomson built the TV.
If your universal remote doesn't have an input key, you probably need a higher end remote (one with that key or one that can be programmed from a computer). Alternatively, you can get an exact replacement remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HD52W58&uuid=12927154203570 .
I hope this helps.
Dec 18, 2010 | RCA HD52W58 52" TV
RCA TV model F27252GY. Don't think I have original remote. Need to set to input or video channel to use my new DVD. How do I do this?
You can try channeling up or down to get to channel 99.Rca in the past has used this to get to the video input. If this does not work you can buy a universal remote. In most cases, after programming the universal remote the major functions such as channel select, volume control and input select will work.
I hope this helps.
Skyassoc
Dec 12, 2010 | RCA F27252GY 27" TV
Input channel with no remote
You should be able to select the AV input with an Input or Menu button on the front of the TV.  If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
May 28, 2009 | ESA ET427E 27" TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't get the channel select to go to av input or video input
A universal remote in most cases can not switch this TV into the AV mode...you can but a orignal replacment remote for your TV At www.remotes.com and then you can use all the functions again!
That will fix ya!
Please rate my response!
Thank You!
Jan 17, 2009 | RCA 32V430T 32" TV
Can't access video input channel
I believe you need the original remote to switch the input to video . I found the remote shown at PartStore.com with the original RCA part number 242524 at about $37.00 and also at MCMelectronics.com at around $31.00. There may be other sources also. Good luck.
Dec 30, 2008 | RCA F27628 27" TV
External input
I'm not overly familiar with your brand, but generally there are 2 ways to get to the AV input.
1) Use the TV/Video button on the remote (if there is one)
2) Channel up or down from the last channel at the high or low end. In other words: channel down from channel 2 may bring you to the AV input.
Hope this helps,
Dan
Sep 23, 2008 | Orion Televison & Video
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Sanyo DS31520 31" TV Logo
189 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
