Question about Uniden GMR638-2CK (22 Channels) 2-Way Radio
Two way radio cross model compatbility
Can i use a uniden model to communicate with motorola model handset or with another uniden model?
I have a pair of 6 Mile range uniden and i am plannig to buy another pair of 10 mile uniden. can i have a one to many using the four handsets. what should i do for that
-Nagu
    Brigadier General:
  • 6,966 Answers
Normally yes just as long as the frequency assignment to each channels are the same and no security/locking (such as (CTSS) is in place.
You have to check if the frequency settings of the Motorola matches those of the uniden.
Good luck and kind regards.
Posted on Oct 23, 2007
TLKR T60 and Amytel AW1010T. Is there any way to pair all four together? (Walkie Talkie)
I would suggest making sure all units are on the same channel. Then check to see if the amytel units use a tone to control either receive or transmit or both. If so, either turn off the tone or find that tone on the Moto units.
Hope that helps some.
Aug 28, 2017 | Motorola Radio Communications
Why does screen indicate "searching"?
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
or it will display "Registration Failed"
Mar 20, 2016 | Uniden DECT 6.0 Cordless Phone
How do I get the Motorola T5000 and Boafeng UV-8D radios to communicate with each other?
check you settings in the radio,follow your instruction manual for the radio
Jun 11, 2015 | Motorola TalkAbout T5000 2-Way Radio
HV-800 not communicating with my phone
my handset in not conect the mobie my mobile model is huawei lua-u22
Jan 23, 2014 | Radio Communications
Uniden pmr 1188
If they both cover FRS/GMRS frequencies, they should be able to communicate
Mar 03, 2013 | Uniden Radio Communications
I need help in pairing my Uniden DECT 3035+1 handsets to my Optus wireless home ph handset
Have a look at this video.
Uniden Phone Reset, Restore, and Deregistration - YouTube
? 3:09
https://www.youtube.com/watch?v=9B0DwYmk-e0
Nov 9, 2011 - Uploaded by votauno
I used it to finally fix problems with my Uniden phone. Read more ... Press and hold delete on the base while ...
Make sure you have the phone lead into the correct socket. I doubt very much you can pair another phone with a cordless set of a different make.
Please remove the bit with your phone number in it. This site get 7 million visitors a year. Many may wish to phone you for a chat :>)
Your Huwai instructions are here. Don't you know any 14 year old lads? They are usually a whiz at this stuff.
Andrew - Fixya Moderator
http://fastlabs.co.za/sites/default/files/Huawei%20F685%20User%20Guide%20EN%20V100R001_01.pdf
Jul 27, 2017 | Lands Phones
How do i program a uniden bearcat sc150 scanner
my parents gave my son a uniden bearcat twin turbo sportcat SC 150 Y. How do you program it
Jan 11, 2010 | Uniden Office Equipment & Supplies
Uniden cordless phone
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Comms problem between motorola t5522 and t5720
Are you sure both radios has the same Squelch Code and QT?
Jul 07, 2007 | Motorola Talkabout T5720 (7 Channels)...
Uniden GMR638-2CK (22 Channels) 2-Way Radio Logo
131 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
