Question about Lomo Holga 120 CFN Medium Format Camera
Shutter release button (not hearing that "click")
I have yet to take pictures with my Holga 120 CFN. Recently put batteries in it to see how the flashes look, awesome. I picked it up today and pulled the shutter release button and I don't hear that nice clicking noise. I noticed inside there is a silver wire that seems to not be moving how it was when I first opened it. I'm assuming this is what makes the clicking. I don't know much about the mechanics of a camera, even a simple on like this. I hope this is reparable or neglible in the taking of photos. It seems the shutter is not quite "releasing" or something.
  • 39 Answers
Same happened to me, i tooke it to this nice place to repair and they charge me 10 usd. But it has to be someone that WANT'S to repair it, because i tokk it to other places, they took a look at it and say there are no spare parts and didn't want to doit.
Posted on Jul 10, 2009
  • Luis Fuentes Pimentel Jul 24, 2009
    Those wires go off all the time, try this you migth want someone eperienced in clocks or mecanic cameras to help you.
Bought holga pinhole lens, set camera to Manual, but view finder is blank as well as pictures
Are you setting the exposure properly? The pinhole lens requires a much longer exposure than usual. Try pointing the camera out the window at a daytime scene (not directly at the sun!), set the ISO at 200, and the shutter speed at 1 second. Do you get a black picture now? If you get something, adjust the exposure from there by changing the shutter speed.
Dec 02, 2013 | Holga Pinhole Lens for Nikon DSLR Camera
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
How do I upload pictures from my Holga 120 CFN onto my computer ? is there some sort of cable that can do it or what?
This is a film camera, you cannot download from it. You need either a film/slide scanner or a regular scanner to scan in the pictures themselves. Sorry.
Dec 04, 2010 | Lomo Holga 120 CFN Medium Format Camera
In my holga 120 cfn the flash doesn't go off when i press the shutter. the batteries seem fine and the orange light turns on, but when i press the shutter nothing happens. a couple of times it has worked,...
The flash would fire as per the requirement, in auto mode.
If the ambient light is enough then the flash will not fire.
In case you need to use the flash in bright conditions (e.g. For using as a fill flash) please repeatedly press the flash button (The one with the lightning symbol on it) till you get a lightning bolt symbol on the camera display.
Now your flash will fire on every shot that you click!
Please ensure that you revert back to the Auto mode once done.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Sep 19, 2010 | Lomo Holga 120 CFN Medium Format Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Holga 120 sponge inside falling of and damage films
Look for a replacement foam/seal kit on the internet.
Jul 20, 2009 | Holga 120FN Fixed Focus Camera with...
POLAROID
You don't need one, put the film in and shoot, with or without flash. But you can try here.
Jan 13, 2009 | Lomo Holga 120 CFN Medium Format Camera
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Broken flash
okay my holga flash was broken too....the batteries were working just fine cus when i turned it on, the little back light came on and the whining sound happened, but then click...no flash! so i took the back off and made a small repair and it worked!
so this is how to fix it (if its the same problem...i.e. everything electrical is working but the actual flash):
use a small screwdriver to remove the two small screws inside the camera (take out the frame and they are on the bottom and top). the front will pop off and you should be able to see the wiring.
where i circled in red was the problem. that curved metal piece at the bottom was too straight and was not making contact with the shutter (the top little metal prod sticking outta the circle) when i clicked it. so just bend it forward to how it looks in the picture...then do a practice click to make sure it makes contact. you can even try it with the batteries in, but be careful!! its electricity!
hope this helps!!
Aug 19, 2006 | Holga 120CFN Film Camera
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
Photography Logo
169 people viewed this question
Top Lomo Photography Experts
Are you a Lomo Photography Expert? Answer questions, earn points and help others
