PLease could you help me as my boss is out of the city.
We have a large freezer, 2 doors, stainless steal, from Turbo Air, modele TSR-49SD.
The problem:
In a pediod of 3 or 4 minutes the temperature goes from less -14C to up to +8C.
And I disconnected 2 or 3 times and plug again but always the same problem.
Is there any solution to do?
my email is [email protected]
many thanks
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
since you did not supply the entire model number, don't know if this is a cooler or a freezer. if a freezer, -10 is good. if a cooler, not good. could be multiple reasons for low pressure if a cooler. you should also consider the high side pressure too as this can also help indicate a short charge. more info is needed to continue.
this is happening because of the new gaskets, what you do is lay something against the door or doors overnight and tomorrow they will be great. hopw this helps.
Give Rick a call at Restaurant Parts and More. Turbo Air also makes Master-Bilt. Rick can probably get what you need. Just have the model and serial. He's good at this stuff. 1-888-814-1110.
