Question about Visual Land V-Touch Digital Media Player
Music can not be accesed through music folder on main menu no mattter what I do
  • 68 Answers
Go to files then audio select file go to the extras part of it and click add to list. Then it will show up.
Posted on Oct 10, 2009
HOW CAN I PUT MUSIC ON A PSP
just connect your psp via the usb connector at the top portion of your psp, connect to a computer, then at the MAIN MENU, or per say when you open the memory card, you should see the folder in all caps, PSP, VIDEO, MUSIC, PHOTO, if you can't see one of these mentioned, you should create a folder, rename it in all caps, MUSIC, then open that folder then put your beloved music, hope this helps.
sneaky eyes
Apr 04, 2010 | Sony PlayStation Portable (PSP) Console
Digital Audio Player XA-F107B. When I downloaded from Windows Media on Windows Vista I good see the music being put on by the "wtiting" going across the screen of the player. But when I tried to...
is the file format you are sending to the player supported by the mp3 player? generally mp3 files are the best bet, they should work on most devices.
Aug 26, 2008 | JVC Audio Players & Recorders
I dont know how to put music on my mp3 player
all you need to do is copy and paste the music files you want into the AUDIO folder of Removable disk:F, which should be accesed by going into My Computer and then opening Removeable disk F, where you should see the AUDIO folder along with the other folders of the ematic;if u dont see an AUDIO folder,make one
the CD is just for uploading videos onto the ematic mp3
Jun 29, 2009 | Beond Ematic EM304CAMB Digital Media...
Deleted folders, it now says No music file for my music
When I couldn't find music files I went from the main menu to music to browse music - the last option on this menu - normally they would all be there ... If not you can go from the main menu to browse files which takes you straight to everything in your mp3 player, select music and the list would be there also.
Hope this helps =)
SEE --->Adrenaline Junkie
Apr 29, 2009 | Samsung YP-S3JAB Digital Media Player
GPX ML648B mp3 player main menu problem
To get back to the main menu just hold the mode button on the side
for a couple seconds or so. You'll get back to the main menu where
you can use the up or down volume buttons to get to settings and folders.
To see all your folders select the top (root) folder and wait a few seconds.
You'll be able to figure it out from there.
Apr 12, 2009 | GPX ML648B MP3 Player
Can't play all music, only plays one folder at a time
should have a setting under main menu that says play all try that
Mar 12, 2009 | Delstar DS 31024 MP3 Player
File system err on spi digital audio player
Click menu and scroll to the setup screen and hit reset.
then go back to the music it will say file error then use the right button to browse to next song and you will see your songs. If however in the music you don't see any songs (number 1of 64 or whatever) then you have to reload your songs.
Next, if that does not work. Go to setup select format complete, (note this will reformat the player) then go to your computer (in explorer) and copy the music right to the music folder (only songs don't copy folders into the music folder on the device.)
then go back to setup, select reset and go back to music menu. You may still have a file error just hit the next button and there are your songs.
Feb 10, 2009 | Audio Players & Recorders
IPOD how to move music
hi,
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Step2
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Step3
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Step4
Hit "OK" and click "Apply Preferences."
Consolidate Music
Step1
Move all your music to one place to make the transfer easier.
Step2
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Step3
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Step4
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Step1
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Step2
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Step3
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Step4
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Step5
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Step1
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Step2
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
Step3
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Step4
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Step5
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Dec 15, 2008 | Apple iPod nano 3rd Generation
I can't find my songs or hear them
I came across the same problem with my Muvo V100. It appears that the unit has a folder access limit of some kind (seems to be 24 folders not sure what detrmines the ones it chooses). I synch with Windows media player and it creates a folder called Music in the root. Within that folder it places sub folders named for the band that the music is from. Within those folders it creates yet further sub folders with the name of the CD the music came from and then finally within those it places the MP3 or WMA files. It appears there may be too many sub folders for the Muvo to be able read all the music. I took all of the MP3 and WMA files and pulled them out to the main Music folder. I then deleted all of the sub folders named for the bands and the albums. When I start the Muvo now it allows access to all of the songs. There may be a way within Windows media player to configure the synch so it doesn't create all of these sub folders. I've not checked. If it is then it would eliminate the manual work of pulling the music files out to the main Music sub folder.
Jul 01, 2008 | Creative Labs Muvo V100 MP3 Player
Visual Land V-Touch  Digital Media Player Logo
Top Visual Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
cwh20002
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
