Question about Whirlpool 24 in. DU940QWD Built-in Dishwasher
When we turn on the dishwasher it doesn't fill with water
We turn on the dishwasher. The light comes on to wash. No water enters the dishwasher. It will go through the wash cycle with no water.
  • 431 Answers
Hi I am vortash it sounds like this is a water level switch ( vacum ) problem it is telling the machine there is water in and the machine carries on and doesn't open the flow valve to put the water in .. as it thinks it is full . or the controller is faulty and need s repalcing .. try replacing the level control first as this would be cheaper than the programer.. Regards Vortash
Posted on May 31, 2009
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
It is leaving a white film on everything.
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | Kenmore Dishwashers
Dishes come out dirty white film and food
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Please rate the solution if you feel I've helped you
Sep 02, 2010 | Kenmore 13769 / 13764 / 13762 Dishwasher
Maytag quiet series 300 dishwasher leaves glasses on top rack with film on it. What can I do??
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
Aug 26, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher leaves a film of soap on dishes. what needs to be cleaned inside as far as mechanics or is this dishwasher done?
Aug 05, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
My profile dishwasher leaves a film on the glasses.
Oct 31, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwashers Logo
228 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
