Question about Coleman Powermate Powermate 5000W Generator
My Coleman Powermate 5500 is lose inside its frame
The rubber mounts no longer sit on the frame and it moves around. I can not find where the mounts reconnect to the frame. HELP !!
  • 24 Answers
Rubber feet normally attach via a bolt or screw through the center of the foot. Look for a bolt or screw were the feet use to be. The rubber may have torn free, so you may need to glue or replace the feet.
Posted on May 31, 2009
To much noise
They do have a lot of vibration. Check all bolts to be sure they are tight. Set it on something that will help quiet the vibration (rubber mat or the like). If it is exaust noise, how old is the unit and could it need a new muffler? I piped the exaust on mine into a larger muffler mounted on the frame with rubber grommets.
Sep 25, 2010 | Coleman Powermate Portable Generator...
I have a Coleman 5500 with Tecumseh motor and it has a really, really slow oil leak when it when it is sitting in the shop not running. I can't tell where the oil is coming from. Any suggestions?
Look for a crack in the crankcase... possibly near a mounting boss. Also oil filler plugs sometime leak if overfilled.
Suggestion: Use some "gunk" engine degreaser to make it sparkle so you can spot where the leak originates. You probably need to put it up on a bench OR use an inspection mirror.
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
How do you seperate the generator from the engine
there is screws that mount it to the main frame take those off then the engine is free but still with the electric parts ther are screws that take apart the engine from the generator unscrew those with a socet rench than insid there will be 4 more take them off and the it is one engine with no generator!!!
the only problem is now your gas tank is in the top off the frame so you will need a different gas tank it you will build somthing around the engine itself.
That one was easy!
use your eyes!!!!!
Oct 24, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Coleman Powermate Powermate 5000W Generator Logo
100 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
