Question about Cyberhome Progressive Scan DVD Recorder with Remote Control
DVD on light comes on for a few seconds and then shuts off
On switch goes on for a few seconds and then imediately set shuts off
  • 6,784 Answers
HI, this will occur when there is a power supply circuit fault that is located on the power supply board. this could be a failed capacitor or resistor of some sort.you will need to replace this damaged power board if possible to restore normal function.
It is unable to hold a proper AC current at this time.
Posted on May 31, 2009
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
Recently had oil changed in 2011 ford expedition limited. shortly thereafter the "change engine oil soon" light came on and will not go out. how do I reset this warning light. thanks in advance...
1.) Press the TRIP/RESET button to cycle to "SETUP MENU HOLD RESET".
2.) Now press and hold the button for 2 seconds until "RESET FOR SYSTEM CHECK" is displayed, then release.
3.) Imediately press and hold button for 2 more seconds until "Oil 100% RESET IF NEW" is displayed, then release.
4.) Imediately press button once to display "HOLD RESET IF NEW OIL" and release.
5.) Imediately press and hold button for 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Aug 08, 2011 | Ford Expedition Cars & Trucks
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Pumps for a few seconds then stops & pumps again for another few seconds & so on
The toilet will flush normally and shut down. Then imediately after it has shut down, as it should, it will start up again and keep going through the flush cycle until I unplug the power going to the pump. After about ten minutes, I can plug it back in and it then will not start up again until I press the flush button.
Jul 01, 2009 | Saniflo Sanibest macerator with multiple...
Lights come on but goes off nothing comes on any display. this was after someone put a code in it to bypass the brake safety switch. now the lights come on briefly and then everything shuts down
Normally you would ground the safety switch wire and not enter a code of any sort.
You need to reset the unit to factory settings, should be in user guide.
May 08, 2009 | Jensen's VM9312 Car DVD Player
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Cyberhome Progressive Scan DVD Recorder with Remote Control Logo
51 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
