Question about Toshiba Satellite Pro L350-S1001X Notebook
Wish to make a recovery disk
How can you make a recovery disk for Toshiba L350d?
  • 4 Answers
Toshiba usually ships laptops with recovery cd/dvd sets.
If you have captioned recovery set, make sure to make a backup copy.
If this series no has recovery cd/dvd, must be a hidden partition for recovery in the hard drive. For make a recovery disc find the sotware loaded in the laptop (must be there) and make a recovery disc set. Be aware that some manufacturers limit the use of this particular software (you only can make one cd/dvd recovery set).
In the worst scenario that the recovery partition is no present you must load Norton Ghost v14.0 and make a full backup to one external hard drive (USB) in order to recover te operative system, drivers and software in case of disaster.
I hope this help you to solve the problem.
Posted by MCampos
Posted on May 31, 2009
Where is cmos batterie on L350d
attached to the mother board you have to remove the case.
Jul 09, 2014 | Toshiba Satellite L350D PC Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I had to wipe and recover my toshiba satellite L350d resulting in now being unable to use my webcam. i was thinking that the drivers werent on my recovery disks. i dont know anyhelp would be much...
You should have created an "Applications and Drivers" disk along with with recovery disks. After your computer is started and you are at your desktop, put that disk in your CD or DVD drive and allow it to come up. Then browse to the webcam driver and double click on it and follow the prompts.
If the DVD drive doesn't automatically show the disk go into "my Computer" or "Computer", right click on the DVD drive and select "open" or "explore".
If you didn't make an "Applications and Drivers" disk, from start go into "All Programs" and look under "Toshiba" or "Toshiba Utilities" until you find the "Create Recovery Disk" wizard, then click on that and look for "Applications and Drivers", then follow it out.
Sep 10, 2010 | Computers & Internet
My windows 7 home premium i can't recovery
I suggest you to download a recovery software such as : http://www.recovermyfiles.com/ then recover your files, then save them in an external hard disk, then format your laptop.
You can't use windows recovery maybe because the laptop didn't install windows successfully.
Wish it works.
Jul 14, 2010 | Toshiba Computers & Internet
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
My toshiba L350D will not pick up my wireless network
this is your solution
config your router to your Toshiba L350D
and copy the IP address thats all...
Sep 20, 2008 | Computers & Internet
System Recovery on a Toshiba
you can get a copy of it on line just search for windows recovery disks and het search ok wish lots of luck mike
Aug 23, 2008 | Toshiba Satellite A215-S4747 Notebook
Recovery disk
Thank you so much for your reply. I wish I knew more about computers, and I hope you understand why I need your help. I am a 24 hour caregiver and am not paid for my work, so any help I can get is appreciated very much. I think all I need is to find out how to contact Toshiba. Their 800 number and website is not user friendly if you know what I mean. I only need a new recovery disk and am willing to drive thousands of miles if that's what it takes to find one. So if you or anyone could please point me in the right direction I would be on my way to the first step in solving this problem with my laptop. It's not for me it's for my daughter Shelly. She has Williams Syndrome and is desperate for her laptop to be fixed with any kind of operating system.
Thanks,
Mark
Feb 15, 2008 | HP Pavilion dv6000z Notebook
Toshiba Satellite Pro L350-S1001X Notebook Logo
298 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
