Air pump runs but don't pump
SOURCE: manual for black and decker electromate 400
I went to the Black & Decker site and downloaded the pdf manual of the electromate 400. It says you're supposed to charge it until you have one red light, one yellow light, and one green light. I expect that 2 red lights and a green light means it's not fully charged. The manual also said you can't overcharge using the 120 V. method. Good luck.
SOURCE: black and decker air station won 't work
My Air Station blew a fuse also. The fuse that came with the inflator may be a bit too small amperage wise so I stepped up to .25 Amps more which is just a very small increase.
It is really ill advise to solder a wire in the place of a fuse. You are just asking for it.
The way I did it is I went to my local Radio Shack and got a small fuse holder with red leads and 1.5 Amp fuses. I soldered the fuse holder in place with the new fuse. And now I don't have to deal with any more solder. Just twist the fuse holder, take out the burnt out fuse and replace it with a new one. And wahlah. I'm back in business again.
