Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi 18v One+ battery won't hold a charge. I have two of them and neither one will hold the charge. The charger is the Ryobi 18v charger plus. I have the same problem. As soon as I put the battery in the charger (even if it is dead) the "charging", and the "fully charged" lights both come on. Even if I leave it for a day the battery will not charge.
  • 37 Answers
If it's both of them then i am thinking you have a faulty charger. i have seen mine do that, i got a new charger and it worked properly.
Posted on Jun 01, 2009
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
I have a P115 Ryobi Intelliport charger , will it charge the new lithium 18 V battery?
Ryobi P115 is an 18V battery charger. However, Ryobi Manual did not mention the current rating of P115. if the current rating of Ryobi P115 is 50% higher than your 18V Lithium Battery it will charge. but if it's less than or equal, it will not.
Nov 29, 2017 | Ryobi Drills
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
Jan 02, 2015 | Ryobi Drills
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a ryobi 18V battery and the only charger I have is a ryobi 14.4V. Can I charge the 18V battery on that charger?
Hello, unless the charger specifies that it charges 18 volt, it will only charge a 14.4v properly. If the battery fits the charger physically, then the most you might get an 18v to charge at is 15 or 16 volts. Your battery life will be shorter and you might damage the charger. I hope this helps.
Jan 12, 2011 | Ryobi Garden
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
I have a Ryobi 18v drill with battery 130429002 that will not hold a charge. Expensive battery with very little use. Can you help?
If both batteries won't hold a charge the problem may be the charger (not providing a full charge). If one battery is OK and one not holding a charge, the problem is probably a defect with the battery. I know there expensive, (I recently had to replace one for DeWalt).
Aug 18, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Does it not hold a charge, or will the charge not indicate "fast charge"? I had to apply a initial jump charge on the battery to get it up to 20 volts, then I put it in the Ryobi Charger, and it started charging it.
Mar 29, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
761 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
