Question about Aquabot Turbo T2 In - Ground Pool Cleaner
Won't go in shallow end to clean
Our Aquabot Turbo T cleaner only stays in the deep end of our 20 x 40 pool while cleaning. It is 1 year old. Last year it worked fine.
    Problem Solver:
  • 15 Answers
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
Posted on Aug 22, 2009
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Doesn't clean shallow end
try aiming the return ports to direct the cleaner to the shallow end
Jul 31, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Aquabot is pushing out water but will not move to clean the pool
I am not sure if this is the manual that you are looking for, or not, but just in case. If you following the link below it will take to you the T2 User's Guide, with the trouble shooting.
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/support-files/aquabot-turbo-t2-manual.pdf
According to the trouble shooting guide:
Pumps Water, but Does Not Move or Moves Slowly
1. Remove any foreign matter that may be obstructing Drive Tracks.
2. Check Drive Belts and Tracks. Make sure they have not slipped out of place and that they're not loose.
3. Observe Drive Pulley, if it is not moving contact Customer Service.
Jul 05, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot goes in one direction
Find a looooong straight area and, starting from the Aquabot, hold the cord straight and straighten it out by letting the cord twist so it isn't all gnarled and twisted - move down the cord, always keeping one hand firmly on the end of the cord closest to the machine (to prevent it from re-twisting). You'll find that the cord will spin like a top as you get closer to the end. Once untangled, pull down on the metal rings under each end of the top floating handle (may require a pull and a slap against the handle). MAKE SURE THE HANDLE IS LOCKED IN A DIAGONAL POSITION.
Jun 17, 2009 | Aquabot Turbo Robotic Pool Cleaner
Cleans only a bout 50% of my pool and doesnot clean walls. My pool shape is a foot print.
Both of these problems could be the installed floats. There are 3 of them normally installed, and they do have a finite service life. Old ones often absorb water, making the unit not cover the full pool area or climb walls, S. Christian dansker01@msn.com
Jun 15, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
May 11, 2009 | Aquabot Turbo T
How do you change the rubber traction belts on the aquabot turbo t2.
First of all your cleaner is under warranty for 4 years or 300 cleaning cycles and is prorated. That being said, here is the schematic and contact info. http://www.aquabot.us/parts/aquabot.html
May 07, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Turbo T2 In - Ground Pool Cleaner Logo
853 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
