Question about Garden
How to replace a fuel line
How to replace a troy bilt gas hedge trimmer fuel line
    Problem Solver:
  • 9 Answers
No biggy, you need to buy the same size fuel line tubing, preferably from the dealer, and replace it by undoing the tubing fasteners, little clips you undo with a pair of pliers. Before doing this, make sure you cut off the fuel line valve which should be right under the gas tank, if none, empty the gas tank in a seperate container. Good luck.
Posted on May 31, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Wh does my electric hedge trimmer shuts off when I angle it.
It is not getting enough fuel for some reason. Either water got it, the gas is bad, the line may have a hole in it, ect. Check fuel/fuel tank
Jul 29, 2014 | Troy-Bilt Troy Bilt Tb24htb 24" Dual...
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
Need to replace fuel lines on my Troy Bilt gas hedge trimmer. Where can I get replacement fuel lines... or better yet... what size are the lines and where can I buy a few feet of the lines. Note: I...
Replacement fuel lines should be readily available at your local lawnmower repair shop. Your TroyBilt hedger uses fuel line that is 3/32" (2.4mm) interior dimension, 3/16" (4.8mm) outside dimension, with a 3/64" (1.2mm) wall dimension.
Most manufacturers don't offer replacement line, only fuel tank assemblies. Find your local shop, and try to get the TYGON brand...it is yellow. Tygon lasts the longest. You should be able to buy it by the foot for less than $2 per foot. You will need 2 feet of hose to replace both lines.
Make sure to clean the in-tank filter when replacing hoses.
Good luck.
Oct 20, 2010 | Craftsman 22" Gas Hedge Trimmer
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Bulb stay compressed for some time - no fuel to the carb
Replace or rebuild the carb or... get a good trimmer that's not a RYOBI sold under the names of Troy Bilt, Bolens, or MTD Yard Machines. My 2 cents. :)
Aug 06, 2009 | Troy Bilt Tb70ss Gas Trimmer
Where is the gas filter located on a troy bilt trimmer?
The fuel filter is inside the fuel tank. Replace the fuel filter. Do not clean it.
Apr 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
387 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
