Question about Ryobi Cultivator
Was running then died
WAS RUNNING GOOD then it lost power pulled down and died .will now not start
    Problem Solver:
  • 9 Answers
I would check your oil level first, they have safety stops when oil level is low. Change the oil while you're at it if it hasn't been done for a while, if it still doesn't work, empty the gas in the tank including the one in the carburettor float housing, spray some carburretor cleaner while you're at it, and put fresh gas in the tank.
Posted on May 31, 2009
97 buick century was running after jump started, when put in reverse it died and wont start when jump start, no chimes or lights come on at all
Dangerous practice to try & jump a near dead battery
Always try charging a battery, that is only a couple years
old & not run down more than two or three times
If the battery is dead & reads less than 12 volts, have a parts
store test it or just replace it.
Jumping a cars battery is not a fix for anything,so I fail to
see how your lost & have not addressed the battery issue,
so you can continue on with other testing,if needed
Sep 24, 2014 | 1997 Buick Century
ZX2 ESCORT 1998
You haven't flooded the engine correct, check the spark plugs. Also, how fresh is the gas? Try shaking the car to get the gas mixed up and try cleaning out the cylinders with a torch to blow out excess gas. You should also either try cleaning the spark plugs or replace them if they look bad. It is starting up fine, correct? The alternator is good, right? I believe it is since it sounds like you didn't drive it long enough to drain the battery but check it anyway. By losing power, did the electronics start shutting off first or did the engine die first as this would show whether the alternator is bad or not. Please answer my questions and get back to me on what shut off first when it died and I will help you narrow down the problem with this car.
good luck
Jun 02, 2008 | 2001 Ford Escort ZX2
2004 dodge ram while driving about 30 mph I heard a clicking sound and truck started running rough, I turned on highway and tried to speed up it made the same clicking sound and while pulling off road it...
Sounds like you overheated, the clicking sound could be preignition ping. Check coolant lever. Don’t fill when hot, let engine cool down before refilling coolant
Nov 07, 2017 | 2004 Dodge Ram 1500
Harley ignition problem
The alternator is bad. IT is not charging the battery. When the voltage drops on the battery it dies, When you jump it the bike starts because power is coming from some other source but when you disconnect that source it dies because the battery has not charged back up.
Sep 01, 2013 | Motorcycles
2002 HD 1500 Chevroley 4WD 4 door truck engin lost power and died could start but when acelarated died max rpm 800 pulled filter turned key on pump shot a stream of gas 3 ft and stoped ran only secon
It is normal for the pump to run for two seconds when first switched on to pressurize the fuel system. It will turn on again when cranking and while running. I would still suspect the pump given your symptoms, however other problems could also give you the same symptoms. If it is the original pump from 2002, or more than about 7 or 8 years old, I would definitely replace it, and the fuel filter. Often the pump will go intermittent. I had one that I could restart and get down the road by hitting the bottom of the gas tank a few times!
Oct 18, 2017 | 2002 Chevrolet Silverado 1500HD
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Turns over but wont stay running or idle
Sounds ike the fuel pump died. As they get old and your car is about that age the start to overheat after being in use for a while. They stop pushing out the fuel consistantly and then stop working all together. Sometimes letting them cool back down will allow you to use it for a short while before it dies again but in your case it sounds like it just gave out. Remember fuel in the tank helps cool the pump when in use.
Tis is a good place to start, good luck.
Joe
May 21, 2009 | 1991 Saturn SL
Engine won't run....
Try taking a look at the catalatic converter if it is clogged it would make that happen no power and dies alot because it is clogging exhaust
Jan 29, 2009 | 2000 Nissan Frontier
Ryobi Cultivator Logo
153 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
