Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
