Question about Toshiba 50H82 50" Rear Projection Television
Toshiba 50H82 blown fuse f470
My Toshiba 50H82 has worked great for the past 3.5 years until I recently hooked up an old Voom High Def receiver to get over the air high def. Picture was beautiful but the tv would act up sometimes on 720p, the screen would turn bright white and might turn off on its own if I didn't turn it off quickly. But no problem with 1080i. I turned the set off one morning when the picture had turned all white and after that I had sound and no picture or menus also no glowing filaments . I found fuse f470 blown and soldered on a temporary inline fuse. This fuse may go to the flyback transformer but I'm not sure. Now the set turns on for a second and then shuts off with a blinking power light. I have a Power/Def board on its way but I'm almost afraid to install it in case its something else that might take out the new board. Could using 720p resolution put extra stress on this tv? Any suggestion on what could have caused this? Also my tags fell off the three anode leads, does it matter what order they go into the transformer?  I live to far away for a service call. Thanks for your help.
  • gxp8 Oct 27, 2007
    Installed power/def board and everything works great. It even took care of the zig-zags on top of the screen I thought were related to bad caps in the hyper board.
  • gxp8 Nov 04, 2007
    hi smellycat, I actually ordered the board from Sears Parts just in case I had to have them finally come and fix it right. They get there parts from PTS Electronics ( so I guess you could order from either one for about 190 delivered which was a lot cheaper than the $300-500 quote I got to fix the tv. Its actually pretty easy to install. Label all of your connections real good! The anode cables(look like spark plug wires) are a little tricky, roll the boots up, give them a little turn and pull. The board also goes under little tabs on the left, make sure the board is under them before you tighten the screws. Good luck. Let me/us know how you made out.
  • 1,694 Answers
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Posted on Dec 19, 2007
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
Can get analog stations recorded but not hi defination
Hi, unless the VCR/dvd recorder is hi def then you won't be able to.
Hdmi connection is hi-def, I think you can have a hi-def signal through composite, but it's your recorder thats the problem, it cannot read the number of line a hi-def signal has.
I have just found this.
I hope this helps.
Regards - Anthony
Feb 09, 2010 | Toshiba Televison & Video
Toshiba 50H72 problem plz help!
ok well both of you have had the same problem i did... to fix the picture problem check the circuit board pd0074 its the yellowish looking one next to the green one which has the ic's on them... ok on the pd0074 board look for fuses f470, f850, and the f851 to see if they are blown the f470 is what turns the tv on and the f850 and f851 are what protect the convergence ic's chances are they are blown.... the sound i don't know how to fix that problem but i would check all the fuses on that board to find out if one more is blown that what i did but the only thing is that i could get the actually fuses for the tv i was told by a tv repairman in my town to just take 2 wires sodder them on to the fuse and take a glass fuse and put electrical tape around them and it worked like a charm... so i hope this helps you.... the most i spent was 30 dollars for the ic's and the fuses all together and i was quoted at 450 to do what i did myself
Oct 31, 2008 | Toshiba 50H72 50" Rear Projection...
50 inch screen
I will check when I get to work tomorow and see if we have one and I will repost tomorow
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
No video on a 50H82 Toshiba Projection
If the screen is lit, then there is high voltage. If there is no video, and the screen is lit, then there is a loss of video. The fault can be anywhere along the main video path before it gets decoded in to the red, blue, and green compositions.
If the screen is not lit, most likely there is a high voltage failure, or there is a failure in the bias supply for the tubes.
When there is a loss of high voltage, this can be from any of the components in the high voltage area. Some of the main things that go defective are the flyback, high voltage multiplier, and various other small components.
Have you considered to replace the set with a good Plama or LCD set? This repair may end up being on the expensive side.
Jerry G.
Mar 10, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
No video, Blown fuse f470, audio works great.
check your h uot transistorthen check pico fuses
May 26, 2007 | Toshiba 50HX70 50" Rear Projection...
Blown fuse over and over
you need to solder all the connectors and plugs between the 2 boards
Mar 05, 2007 | Toshiba 42H81 42" Rear Projection...
TV Problem After Lightning Strike
check the diodes or the regulator. the diode are most likly shorted that the 4 d's like d800, d801,d802,d803
Dec 26, 2006 | Toshiba 32AF45 32" TV
Toshiba 50H82 50" Rear Projection Television Logo
729 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
