Question about Panasonic Viera TH-42PZ80U Plasma TV
New 42inch plasma turned off while watching, can't turn on
The TV worked about one hour and then automaticly shut off. We are unable to turn back on. Red light flashes at the bottom of the set. We unplugged the set for awhile and tried the controller only to have set start to turn on and shut off automaticly without producing a picture, the contoller then has no effect on the TV, red light continues to flash. Need help.
    President:
  • Panasonic Master
  • 1,779 Answers
Panasonic requires an authorization number first from them. Our parts suppliers require that before we can even order the part. I recommend calling a svc co. to have it looked at, preferably an authorized panasonic service center, it will be much faster.
Posted on May 31, 2009
Sansui 42inch snows after a while of watching!
Nothing wrong with motherboard engine it seems looking like issue with plasma display connector top left and right side , if you good on that to do it yourself then have look pic or send me pics inside http://electronicdoctor.weebly.com Connection may be different on your TV set 4_4_2014_12_20_43_pm.png
Feb 05, 2014 | Televison & Video
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Lg 42inch plasma tv clicks several times before turning on. Then it works fine until you turn it off and back on again. Then the same thing happens. This has just started to happen in last 2 weeks. Any...
You have bad capacitors on the Power Supply PCB. There's probably like 9 of them bad, if memory serves me correctly. I have a tutorial published on a Samsung repair involving capacitors. It's not identical, but the solution is similar. I think in the case of your TV, you'll be looking for 3300uF caps with swollen tops. If after looking over the tutorial you decide this isn't for you, get the TV to a repair shop. I highly recommend you stop watching it and unplug it until you get this fixed. I hope this was of some assistance.
Apr 13, 2010 | LG 42PX5D 42 in. Plasma HDTV
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic Viera TH-42PZ80U Plasma TV Logo
416 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
