Question about Husqvarna Garden
Mowes unevenly. Blades don't match up.
The problem started about two months after we purchased our mower. It started to mow unevenly. There is a difference in elevation of the two blades where they meet in the center of the deck? I have replaced, spindles, pulleys, belts, nothing works.
  • Wesley Strong Jul 06, 2012
    Check the level of the deck. It might look level but staight edge it to be sure.
  • 284 Answers
Make sure when you replaced the spindles that you used all the washers and spacer bushings back identical to the ones you took off.
Make sure your deck isnt bent for some reason where the spindles mount and or the deck itself
level the deck when its on the mower on a level suface,side to side(level) back to front the back just a little higher than the front 3/8 inch or less
proper air pressure in all 4 tires
Also you could add a washer or take away a waher to allow the blades to become level at mid point meeting?
be sure to torque the blade bolts to 35 ft.lbs also
Posted on Jun 01, 2009
    Problem Solver:
  • 13 Answers
I would say the mower deck is warped Invert deck lay strait edge along blades shim bearing housing and or straiten deck.
Posted on Mar 20, 2012
Masport series 20 mowing uneven
check /replace blades
level up the mower deck
the blades have to be parallel to the ground so if wheels are worn or the deck tilts in any direction the cut will be uneven
Feb 03, 2017 | Garden
My 1500 series cub cadet 42" mower with hydro transmission runs good but mowes very slow. What could be the problem?
Is the tractor moving slow or are the blades moving slowly? The belt on the mower blades may be slipping. If the tractor is moving slowly look to see if the transmission needs fluid.
Aug 08, 2015 | Cub Cadet Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
My mowers cuts uneven I replaced the blades but it still cuts uneven how can I level it?
Park mower on a level flat surface ( a concrete garage floor is ideal ) lift deck up until you can put a piece of a 2x4 flat underneath the deck and lower deck until it just contacts the 2x4. loosen adjustment nuts or turnbuckles and adjust until the deck just starts to clear the 2x4. this should level your deck. Now , lift the deck and remove the 2x4. put blade height lever on a known cut length and with a tape measure, measure the tips of the blades from the floor to the blade tip...they should all be the same within 1/8 of an inch...if not then you either have a bent blade, bent spindle shaft, or spindle bolts are loose or misaligned. Your deck could be warped too...depending on how hard a lick it took...good luck !!! ;-D
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
Hi there i have an 18hp 42'cut power kraft deck probleme
Hi ! I have the same mower. It is an older machine and possibly the belt that drives the mower is worn. The belt drive is spring loaded and when you engage the mower by lowering the lever, aspring pulls the deck backwards against the blade. If the belt hasn't been replaced in a while, I would start with that first.
Apr 08, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Mower runs but blades won't engage.
first check for a blown fuse (owners manual will tell location) next try checking the blade engage switch next check the electric clutch good luck
Sep 10, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
42" deck - uneven mowing in the center
yes its repairable & yes it can bend the spendle but most likely the blades is it one that does it or both blades or the center or the sides of deck is bent by stepping on the deck let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
539 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
