Everytime I buy ice cream and put it in my freezer, or popsicles they turn to much. All my meats, TV dinners, and other frozen things stay frozen solid. I've tried adjusting the Freezer and refrigerator temperatures but nothing seems to work.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
