Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Few Problems 1. My C250 connect to my computer but it doesn't charge half the time, but when it does it last for 10-12 hrs of constant use>Why it this?2.My computer is not able to see any music on the device after i formatted my computer, all it sees is a temp file, and a version Document. Why is this?3. I bought a S.D. micro Chip  that works on my cell  but when i plug it into my Device  it doesn,t see it  but by computer reads it as a removable drive. Why is this?4 It will play music for about 5-10 min than shuts off , the setting are set to the max. this is when its connected to the computer. Why is this?I think i messed it up can u help.
  • Anonymous Nov 06, 2007
    when i have it on repeat it only plays it once then shuts off
I'm not sure about your other problems but i have the same problem as stated in number 2. I'm not quite sure why that happens but if you use music match it will show all your songs in a list
Posted on Nov 13, 2007
How long does it take to charge battery for the first time?
Depends on the battery... a "toy" battery may only need an hour or two....a motorcycle battery may need 12 hrs @ 4 - 6 amps - depending on the type of battery....a car battery may need 10 amps for a short time (4 hrs) because they come pre-filled and charged. I NEVER depend on the "charge" of a new automotive battery (of any type)..I always charge them for at least 4 hrs @ 10 amps before initial use!! ...they seem to last longer
BUT - AS a RULE = 10 hrs @ 10% of the rated amperage...
Aug 16, 2017 | The Computers & Internet
Connection problems of my blackberry torch 9800 to mercedes c250 bluetooth
Check whether you have another interfere with the Bluetooth connection in your car affecting the connection,try resetting your phone,and check visibility time in your phone if authorization between two paired Bluetooth are okay or not. Good luck
May 16, 2012 | Cell Phones
I have not used my tomtom for a few months , an when attempting to use it today , it was dead . nothing at all help tomtom xl
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | Tomtom One XL GPS Receiver
Sansa c250 mp3 player connects and will not charge
It takes a while. Try leaving it charged over night, then tell me if you have any problems.
Sep 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Battery charging problem nokia 3230
yes you have get a genuine Nokia battery from an authorised dealer.regards!
Nov 04, 2008 | Nokia 3230
Palm Z22 will not turn on
I had this problem in the very beginning and a few times after. What worked is the following.
Put it to charge for at least half an hour. You won't see it is charging or anything.
Then, while connected to the charger, press the reset button.
Have you guys tried it like this already?
Feb 02, 2008 | Palm Z22 Handheld
Sansa c250 freezes while refreshing database
I got my c250 to turn off while frozen by holding the "menu" and "select" buttons down at the same time for a few seconds.
Jan 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging the c250
Turn it off, and then plug it into charger
Nov 13, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
73 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
