Question about Friedrich QuietMaster SS12L10 Air Conditioner
My AC needs a new 220 cable
When moving AC from one window to another 220 cable got damaged. I need a new 220 calb to be installed so I can use my Friedrich AC
  • 142 Answers
If the damage is close to the end of the cable, simply get a replacement plug end from a home repair store and put it on.
Cut the old plug off and install the new plug.
when you go to buy the cord end, take the old one with you so you get the correct configuration.
Posted on Jun 01, 2009
Question about Dell D220P 01 Optiplex AC/DC Adapter 220-Watt Power Supply HOW DO I USE THIS UNIT TO PROVIDE 12V STANDALONE POWER?
most power supplies have a switch for 120 and or 220 options just move the switch to what setting you want. most power supplies can be used as a stand a lone power supply, if not than you need to request for a 220 watt power supply the can be used as a stand alone for pc or computer use. most computer retail should have them in stock. look on line or at
www.fryselectronics.com/computer/parts/power_supple/stand-a-lone/for_PC_use/220_watts/
type power supplies stand-a-lone 220 watts computers compatible
Mar 02, 2015 | Dell D220P 01 Optiplex AC/DC Adapter...
Whirlpool
I think your old plug is probably 120 and you may need to convert to 220. It's probably the wiring is probably 220 in new home? Or maybe not grounded properly. This is a job for a professional. If you think you know what you doing, we try to save a few dollars by doing it ourselves. But sometimes it is time to call the experts, before we cause more damage and cost us more money. Good luck!
Aug 27, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Put a plug on a 220 wiring. the plug has melted
buy a new power cord with plug on it, remove back of dryer, undo screws on old cable one at a time and install new wire: example---remove a red wire from old cable and then put on the new red wire , move to the next color and repeat. put on back, then plug in. Done...
Jan 08, 2014 | Dryers
My nexxtech multination travel adapter specifically says on the label that it will convert 240/220 V to 120/110 V, but when i plug it into a 220 V wall outlet its output is still 220 V. (I know this since...
It seems your adapter is not a converter for Voltage, but just a plug-converter so it will fit all type of sockets. There's a varistor for safety-protection, but that's all there is. At least, that's what I make up, based upon your description and the manual. See http://downloads.thesource.ca/273/2731445/manuals/manual.pdf
If the converter also should have converted 220/240 V AC into 110 V AC, than the electronics inside is damaged. Actually I think it's just a plug-converter, because there are many devices operating with an internal switched powersupply. The advantage of such technique is it can operate at various AC-voltages, whil only an adapter for the correct plug is needed.
Oct 16, 2013 | Computers & Internet
Damaged cable connecting monitor-computer__need a new one
Is it a vga[blue plugs] or dvi[white plugs]? Depending on which one just about any Walmart, Radio Shack, or Computer store will sell replacements. Hope this helps.
Oct 18, 2009 | Princeton Digital DPP 500 Monitor
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
When i try to move my 1998 chevy cavalier from park to drive, it either stops at neutral or stays stuck on reverse or park, but the lever still moves back and forth it just wont shift gears.
Checked the cable from the shifter to the transmission? They often stretch or break & become difficult to move Or fail to move lever on transmission properly.
Apr 13, 2009 | 1998 Chevrolet Cavalier
Cannot download pictures from our phone
Usually we must use the USB cable delivered in the same package with your phone. You may need to check the calbe bought from internet that whether it is the same model with the one in your package (this info should be mentioned in the product manual).
After then, please check whether you have installed the correct driver for the cable, if not, you may can find it from the website of the phone producer.
Dec 06, 2008 | Cell Phones
Am antennas
Hi, to all. There are currently two types of Bose Wave Radio system available in the market. The first one being the WRCD with the top loading CD mechanism. This unit does come with the Antennae cable inside the box and this should sort out your problem. Another option is using an outdoor aerial antennae and connect this to the antennae port behind the unit. The second one is the new Wave Music System with the front loading tray mechanism. This system uses a unique concept of using the electrical cable included in the box and utilise your electrical pwoer line as the antennae receptor. I recommedn to keeping the pwoer calbe fully extended. Another solution for this is that Bose service centers do have a specific spare parts calbe called the AM/FM antennae cable for WMS which you can simply buy for around 20$ I assume. this basically bypases the power calbe and routes antennae reception through this minicable (brownish colored RJ calbe).
Glad to be of service...
Oct 14, 2007 | Bose Wave Radio
Friedrich QuietMaster SS12L10 Air Conditioner Logo
114 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
