Question about HP L1906 19" LCD Monitor
Miscellaneous hp L1502 problems
I have few different problems with the hp L1502 Flat panel monitors. i hit the power button the screen flashes white and will not display anything else, one stays white, one of them the image is there but very faint, one monitor will display fine but has a vertical green line down the screen. does anyone have any suggestions for any of the problems i am having? any help is appreciated.
5 Suggested Answers
  • 70 Answers
SOURCE: HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Posted on Dec 26, 2007
  • 4234 Answers
SOURCE: HP w1907
This sounds like a digital problem. If the monitor is still in warranty, return it for exchange or repair.
Dan
Posted on Aug 01, 2008
budmrtn
  • 11361 Answers
SOURCE: HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
budmrtn
  • 11361 Answers
SOURCE: I have several of these monitors that won't
It can be as simple as bad caps, or worst case will be bad lamp assembly.
http://s807.photobucket.com/albums/yy352/budm/HP/HP%20L1706/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 09, 2011
Black screen, flashing blue power light
Chek the RAM of your system. Clean the slot and re-fix the ram. If the problem not solved replace the Ram
Jun 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
HP Monitor comes on with bright white screen since changing PC
Try using a different wall outlet to plug in your monitor. Believe it or not this actually may help.
What ever breakers you are talking about to get the monitor going doesn't really have anything to do with the drivers. Monitors are "plug and play" meaning the drivers are installed for you when you plug it in. It"s possible you don't have the connections on securely or maybe one of the pins are bent. Does it say "restore active desktop" anywhere on your screen?
Also possible the power supply isn't strong enough for your lcd.
Dec 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Screen remains black and flashing blue light on power button
I also have the exact same problem. My monitors been collecting dust for a while now and I can't find the solution anywhere.
Aug 05, 2008 | HP f1905 19" Flat Panel LCD Monitor
Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Apr 02, 2008 | Computers & Internet
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
The screen doesn't display anything and the power button is flashing green
Ok I got the same problem. And this is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Nov 30, 2007 | Dell E173FPb 17" TFT LCD Monitor
HP L1906 19" LCD Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
