Blower motor running, but no air coming out of registers.
  • 158 Answers
Air filter may be is blocked and coil is icing up
Posted on Jun 01, 2009
My trane xe 1000 central air conditioning unit turns on and the fan os working, but no air is coming into tue house. The lines get ice on them outside. I left it off all night with no change in status
If you left it off all night and no air is coming out of supply registers then the blower motor is not running. If the system is getting frost on the suction line(the big copper line coming out of the outside condensing unit with rubber insulation on it) within minutes of turning the system on then that will confirm that the blower motor is not running properly.
Unless you are very experienced in working on air conditioning, i would call a professional to do the repair.
If the motor has to be replaced its takes an experienced technician to do it correctly.
It could simply be the run capacitor on the blower motor.
This is probably going to be a 5 mfd capacitor.
Turn off all power to air handler, remove service panel, set your multi-meter to mfd (microfarads),
place the leads on the connections on top of the capacitors securely for 5 seconds. You should read about 4.8 to 5, if not the capacitor is bad.
There are other possible problems that could cause your symptoms, but ultimately your blower fan is not blowing air.
Sep 01, 2011 | Heating & Cooling
How do i change a blower motor in a ford tempo 1992? i have the blower motor lose but the bottom og the glove box bar is in my way. how do i take that out to get the motor out?
Less Air Conditioning
  1. On models equipped with airbag, disarm airbag system as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
  2. Disconnect battery ground cable.
  3. Remove screws securing right ventilator control cable to instrument panel.
  4. Remove screw securing right register duct to lower right edge of instrument panel.
  5. Remove glove box and hinge bar from instrument panel.
  6. Pull right register duct from installed position between air inlet duct and right register opening, Fig. 10.
  7. Remove ventilator grille from bottom of ventilator assembly, then screws securing right ventilator assembly to blower housing.
  8. Remove hub clamp spring from blower wheel hub, Fig. 11.
  9. Pull blower wheel from blower shaft, then remove three blower motor flange attaching screws.
  10. Pull blower motor from housing, disconnect electrical connector, then remove motor from vehicle.
  11. Reverse procedure to install.
  12. On models equipped with airbag, rearm airbag system as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
With Air Conditioning
  3. Remove glove box door and instrument panel lower reinforcement from instrument panel.
  4. Disconnect blower motor electrical connector, then remove blower motor and mounting plate from evaporator housing.
  5. Rotate motor until mounting plate flats clear edge of glove box opening, then remove motor.
  6. Remove hub clamp wheel spring from blower wheel hub and remove blower wheel from motor shaft.
  7. Reverse procedure to install.
  8. On models equipped with airbag, rearm airbag system as described underMAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
Dec 18, 2010 | 1992 Ford Tempo
My unit is running but there is no air coming through the registers.
At the thermostat to the fan to the on position. If air
stilld does not come out, find the blower motor compartment and see if you can see the motor running or if a belt has come off. Check the refrigerant
lines make sure they are not iced up, if they are your
coil is probably iced over. Check to make sure your filter is clean
Jun 11, 2010 | Weather King 10AJA4801AH Air Conditioner
Blower motor not blowing
you will have to replace the blower motor
Aug 11, 2009 | Amana PTH123B35AE Air Conditioner
Low air volume coming from supply registers. Checked filter. Checked charge, 40 low/250 high Checked duct, no leaks or breaks. blower turning.
could possibly have a bad blower motor or on the brinks of one. check the run amps of the motor make sure its doing what it should. if not may need new bloer motor
Apr 22, 2009 | Heating & Cooling
New motor runs but doesn't blow air through the registers
Is the blower wheel turning? Did you by chance have to remove the motor from the blower wheel to work on it? If you did, did you put the blower wheel back on in the correct direction of air flow? Also, did you put the correct capacitor back on the unit so it can get up to the required rpm's? These are things that you will need to check for. If the motor is running and the blower wheel isn't and the wheel is tight on the shaft, then you will have to replace the motor. The brushes may be bad on the unit and it's not turning the shaft. Hope these ideas help.
Apr 09, 2009 | Carrier 52PQ-515---3 Premier Series Heat...
No air coming out vents
Plugged filter?
Blower wheel bad?
Iced over evap coil?
Registers closed?
Ducts collapsed?
Ducts disconnected?
Evap coil plugged?
Start here to determine the problem.
Jun 12, 2008 | 1993 Chevrolet Cavalier
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
