Question about Cobra 29 LTD CB Radio
Cant get SWR below 3.5
Hey,
I have a Uniden PC76XLW, which I have read is pretty much the same as the Cobra 29, that's why I posted here. I have it hooked up in my pickup truck. The antenna is a wilson 5' fiberglass, mounted on a plastic tool box, as far back on it from the cab as possible. I have a ground wire running from the negative shield of the coax where it connects to the antenna to the chassis of my truck. I have checked for continuity, and get good continuity from the positive lead on the PL-259 connecter at the radio to the tip of the antenna. There is no short along the coax or any connecters, and there is also good continuity from the negative lead on the PL-259 to the chassis. I think this is how it's supposed to be hooked up. I cannot get any transmission or reception on the radio, although I can hear faint static. When I try to tune the antenna to the radio with its built in SWR meter, the needle doesn't move no matter if I adjust the tip up or down. It reads well over 3. I'm guessing because there is no short in the antenna system or anything and I can't adjust any SWR that it's something internal.
When I got the radio, it had a blown protection diode, which I replaced. I was using a friend's magnet mount antenna which would get the SWR almost to 2, just to try it out. Now with a new antenna, it worked briefly while I was testing it very quickly, with high SWR (I hadn't had a chance to ground the antenna yet. Did that mess it up maybe), but then once I hooked up the ground, it hasn't worked.
Any suggestions? Thanks
  • halebp May 31, 2009
    Doesn't the chassis serve as the ground plane?
  • 437 Answers
A ground wire will not replace the lack of ground plane. Try a different antenna altogether (possibly one with a magnet mount) and mount it on some metal surface like even the front hood and retest.
I am sure the problem you will find is with the lack of a proper ground plane.
Posted on May 31, 2009
  • Thomas Neubauer
    Thomas Neubauer May 31, 2009
    Think of ground plane as a physical reflector of surface area. You could try bolting the antenna down temporarily to just about anything but the plastic tool box. You need metal under that antenna to act a ground plane. There are antennas that do not require the ground plane. These are special use antennas for things like fiberglass boats etc.
    Because these radios are pretty tough you can even have a friend move the antenna around while you are attempting to take the SWR reading (dead key) and watch for it to fall. Twin antennas (like on big trucks) are easily tuned this way.
    I hope this helps.
Attenna warning light
Is showing a bad swr which will only happen when transmitting. Get a swr meter and patch lead and tune your antenna for the lowest swr on channel 20 or middle frequency of your rigs frequency coverage. Easy fixed.
Jan 12, 2014 | Uniden Pc76xlw 40 Channel Cb
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
I have a cobra ltd 29 bt hooking to a 102 inch whip and cannot get m swr readings down under 3 or it will go up higher then the calibrate triangle instead of down. my antenna is mounted with a gumdrop...
  • Sounds to me like you need to check the connectors and connections on that coax. A cobra29 and a 102" whip is a simple enough set up and should not produce that high of SWR unless the coax or the connectors on the coax are pretty messed up. Also i recommend putting an SWR meter in line.
  • The meters on them Cobras can be accurate sometimes but I trust an inline meter much more.
  • Ground it again to make sure.
Regards, Tony
May 17, 2011 | Cobra 29 LTD CB Radio
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
I have weak talk back signal
Did you tune the antenna??
The antenna needs to be tuned for best SWR.
If the antenna is not the right length, then you will get signal reflecting back into the radio. this is bad and it can damage a radio.
The 29 has a built in SWR meter.
The lower the SWR the better.
Here is how to check the swr.
Turn to ch 20. Put the sf swr cap switch to CAL. Key the radio. With the radio keyed, turn the cal knob up until the meter is all the way to the right on the cal mark. with the radio still keyed, flip the switch to SWR. Where ever the needle falls is your swr reading. The top line is SWR. If it is above 3 this is really bad, and your antenna is no tuned and you are hurting your radio. You need to adjust the antenna length.
Turn to ch 1 and take an SWR reading the way I explained. Then do the same on ch 40. IF the SWR is lower on ch 1 then 40, your antenna is too short, make it longer. The antenna has a way of adjusting it. Usually the whip slides up or down in a colar.
If the swr is higher on ch 40 then 1, it is too long, and you need to make it shorter.
Keep making adjustments until the reading on 1 and 40 get lower, and are about the same.
Then check ch 20 again. It should be low, 1.5 or under. Then you are good to go.
you will find people hear you a lot better, way better then ever.
Jun 30, 2010 | Cobra 29 LTD CB Radio
Need instructions on how to swr my cobra 29 ltd bluetooth
You insert an SWR meter in the antenna line, usually one end goes into the Antenna OUT socket, and the Antenna plugs into the SWR meter, you then tune you antenna coupler, inductor, & final PA, in the final stage, until you achieve a 1:1 SWR reading, this is however quite hard to achieve, so simply tune for the closest 1:1 SWR that you can achieve.
Feb 22, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 ltd bluetoot. with builtin swr meter that reads 2.0 on channels,40,1 ,20 when testing is this low enough .what can i doo to get it lower
what type of aerial are you using? is the aerial near any metalwork ie fencing/metal sheeting etc if so move it away as you could be getting reflected power back into the aerial causing high swr, also 2.0 swr isnt too bad could be better but the swr meters built into cbs are not that acurate, I would use a dedicated in line swr meter (even a loan of one) and compare the readings, I take it all your electrical conections to the aerial are good? let me know and i will try and help, Thanks.
Jul 14, 2009 | Cobra 29 LTD CB Radio
Swr to hi and can t get it down
I hope this will help you on setting your swr put the radio on channel 1 check your swr.
now go to channel 40 check the swr. If the swr is lower on 1 than it is on 40 the antenna must be shortened buy 1/4 inch.until you reach your desired swr.if the swr is lower on 40 than it is on 1 the antenna must be lenthened by 1/4 inch until desired swr.
Mar 28, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ANT light
I believe it to be feedback but be aware of your Standing wave ratio because using a linear amp radiates signal to the point that it could cause that light to come on. There is a problem if the radiated signal is feeding back into the amp a a higher level that it can withstand over time.
Sep 08, 2007 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
476 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
