Question about HP OMNIBOOK 6000 3P800 128/10G CD 14.1 56K HP (F2449WT) PC Notebook
How do i replace the keyboard on a HP Omnibook 6000? I have removed the panel covering the speakers and removed those screws but something is still hanging up in the middle of the keyboard
How i remove the keyboard for a Hp omnibook 6000. I have removed the speaker cover and removed those but there seems to be something hanging it up in the center of the keyboard
  • 256 Answers
Check on the bottom of the Omnibook for a screw that might be holding the keyboard in place. Or it may be a ribbon cable that has to be disconnected. Try to peek under and see.
Posted on Jun 01, 2009
HP Omnibook 6000 Laptop Noise
It could be the fan which may have a noisy bearing.
Jun 26, 2012 | HP OmniBook 6000 Notebook
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
Dell Inspiron 6000 keyboard issues
Sounds like something got spilled on it and keys are sticking underneath. Keyboards are quite easy to remove. Check online for help in removing. I suggest you clean it with rubbing alcohol (after it is removed) and spray dry quickly with compressed air. If that dont help then order one online. Tons of dell parts on ebay. Good Luck.
Nov 23, 2009 | Dell Inspiron 6000 Notebook
How do I install this in an HP Omnibook 6000 laptop
u find in rgiht side of laptop just push your dvd drive in to that position push it untill u heard sound of lock
May 24, 2009 | Computers & Internet
How do i remove cover froma dell inspiron 1525 to replace the keyboard
1) Take out the battery and unplug the power.  Undo the two screws under the battery to release the speaker panel. 2)Pry the speaker panel off and undo the two screws underneath this to remove the keyboard.  Carefully undo the ribbon cable. 3)Do in reverse order to re-assemble.
May 01, 2009 | Computers & Internet
Internet link
No, you need purchase PCMCIA or USB external wireless card, because Omnibook 6000 not have internal wireless card included
Feb 22, 2009 | HP OmniBook 6000 Notebook
HP omnibook 6000
http://www.retrevo.com/search?q=omnibook+6000&rt=pd
The above directs you to the manual of your notebook.Please do rate if this solves the problem.Thank you.
Jun 19, 2008 | HP OmniBook 6000 Notebook
Inspiron 6000 keyboard replacement
You can find how to remove your keyboard here.
You need to remove the hinge cover. Underneath it are two screws.
Good luck
Apr 25, 2008 | Dell 0Y3740 Keyboard
Altec Lansing speakers in laptop
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Jan 14, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
168 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
