Question about Samsung CLX-3175FN Printer
Sanner is locked!
I have a Samsung CLX-3175 which says scanner locked, but there's no way to unlock it! So I do have a scanner, but I can't scan (or copy). Scanner locked is the message im getting Tha manual does not show step by step solution to this
  • 23 Answers
Service Manual at
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Posted on Feb 17, 2010
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Hi I have just purchased a Samsung CLX- 3185 Colour printer, scanner and copier and the screen states ' Scanner Locked'
The scanner may have a locking lever that locks the scanner head so you can transport it without damaging the scanner head.
Locate the locking lever and unlock the scanner head.
Jan 23, 2011 | Samsung CLX-3160 All-In-One Laser Printer
How you unlock the scannerof the samsung CLX 3160fn
The lock is the light green, slide the lock towards the front to unlock the scanner.
Mar 20, 2010 | Samsung CLX 3160fn All-In-One Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
What toner does the clx 3175 take. Does it use a chip as well - which one?
Takes CLP 310
To use Toner refill you need a chip that solder to the main board. search Ebay for reset chip for CLX-3175
run around $40.
Service Manual Free
Feb 12, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Printer making loud clicking/clunking sounds
Sounds like the problem I had where the plastic gears that drive the roller on one of the the toner cartidges are broken.
Your gunna have to take it to a repair shop or send it back where ever you got it. If they won't take it might still be under Samsung's warranty.
Feb 02, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Sanner is locked!
Look at scanner mechanism under glass. See if the clip has popped off of the slide guide "tube". Also, there is a scanner lock on this model. I believe it is near the back by the hinges but you can check the manual to be sure.
Apr 14, 2009 | Samsung CLX-3175FN Printer
Scanner locked on samsung 3160fn- how do I unlock it?
I think you have to call the service. They will change the hole Scanner. Because you can't unlock the scanner by any buttons or mechanical trick!
Mar 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3175FN Printer Logo
1,140 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
