Question about Dell 926 All-In-One InkJet Printer
Printer says cover is open and its completely shut. wont print
I went to lift the cover to place a new ink cartridge, and when i closed the cover the printer shows the cover as being open. so it wont print every time i go to print it says cover open and to close it and continue. but it is closed
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
Posted on May 31, 2009
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Apr 17, 2012 | Canon Office Equipment & Supplies
Changing ink instructions canon MP240
With the printer on, open the paper output tray. Then lift up the scanner unit (with the document cover closed). Make sure the support is holding the scanner unit. Then wait until the cartridges move to the replacement area. Pinch the tabs together to open the cartridge locking cover (it just rotates up). Then remove the cartridge by pulling it towards you. Prepare the new cartridge - remove it from the box and remove the orange tape. Do not touch the electrical contacts or the print nozzles.
Slide the new cartridge into the cartridge slot (color on the left). Then close the locking cover - it should click into place. Make sure the cover is correctly closed. Lift the scanner unit to disengage the support and lower the scanner to close it. Wait for the printer to clean the new print heads before sending a new job to the printer. (It will finish printing a job that was in progress when the ink ran out.)
Note: if the scanner unit is open for too long, the cartridges will move to their home position. Close the scanner unit and reopen it.
You can find pictures of the procedure at Canon's support site: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport . Searach for replace ink cartridge. Altternatively, go to the Brochures and Manuals page and see the manual.
I hope this helps.
Mar 08, 2011 | Canon PIXMA MP240 All-In-One InkJet...
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Need to know how to change printer ink
Do not touch the electrical contacts or print head nozzles on the Cartridge. The machine may not print properly if you touch it.
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (C).
genebur2_1.jpg 3. Pinch the tabs and open the Ink Cartridge Locking Cover.
4. Remove the Cartridge.
genebur2_2.jpg 5. Take a new Cartridge out of its package and remove the orange protective tape gently
6. Put a new Cartridge in the Cartridge Holder.(The Color Cartridge should be installed into the left slot and the Black Cartridge should be into the right slot.)
7. Close the Ink Cartridge Locking Cover to lock the Cartridge into place.
8. Push down the Ink Cartridge Locking Cover until it clicks.
Nov 08, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Print cartridges
    1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
    2. Lift the top cover to the open position until it locks securely into place.
    3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
    4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
    5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
    6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
    Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Dell 926 All-In-One InkJet Printer Logo
    248 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
