Question about Panasonic DMR-EZ47V DVD Recorder/VCR
How to stop a DVD recording and restart it at the place at a later date
When playing a recorded TV show (using a DVD-RW) and want to stop it before it is over and want to play it at a later date from where I stopped it. The Manual(on p.7 under Playback) tells me to press STOP and the stopped position is memorized, but it doesn't tell me what to do next to restart where I stopped it. Can you help?
  • harvardplace Jun 01, 2009
    Thank you, but your advice didn't help. I rechecked the menu and the operating instructions booklet. There is no way to turn this function on or off. The booklet states:"Press STOP; the stopped position is memorized. (resume play function)" Indeed the unit stops ok, but if I turn the machine off, the next day the recoded program starts all over agan from the beginning , not from the place where I stopped it. Any more suggestions?
  • 61 Answers
This feature can be turned off and on in some models so check the menu (and book?) to see if it can be turned on.
it memorises it, it should go back to that place it last was stopped with all the ones i've scene
Posted on Jun 01, 2009
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Recorded movie on dvd-rw will not play on another player
the best format to buy is the DVD-R but make sure your disc has been finalised if you reinsert your disc on the functions screen you should see finalise this is essential for compatible playback hope this helps regards Jim
Mar 26, 2009 | Televison & Video
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Dubbing VCR to DVD... it records for 20 seconds then stops
Try a -RW disc. Only the higher priced DVD recorders can use the +RW disc.
Electrode
Mar 15, 2008 | Zenith ZRY-316 Video Recorder
Recording to Dvd-rw
yes u hav eto use dvd +r disk ok try that 1st please thx nick
Feb 04, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
