Question about HP DeskJet 932c InkJet Printer
My printer has an almost full black cartridge but will not print.
I have an HP 932C and an almost full black ink cartridge. It will not print even though my print option is set for black and white. My color cartridge is empty.
  • nymtngirl May 31, 2009
    This didn't help. I still try printing and nothing come out. I have cleaned the head of the ink cartridge and also changed the color setting to black and white.
    Sergeant:
  • 197 Answers
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
Posted on May 31, 2009
Printer will not print in color, only black. We just replaced the cartridges.
If its an HP inkjet printer you may have set it to print in black and white. To change this setting go to "control panel", then "printers and devices", right click on your printer, then "printing preferences", "advanced", then uncheck "print in greyscale"......Good luck !
Nov 03, 2012 | HP DeskJet 932c InkJet Printer
Printer is not printing, the power light is on, the other lights are off. I click print on the soft ware, properties and other relavant alustments and no response.
I had a hp printer that didnt want to print I found out that if one of the ink cartridges is empty it wouldnt print. I needed to print a letter in black ink so I had to trick out the cartridge by putting black electrical tape over the small site glass(plastic) so the printer thinks it is full,after this the printer would at least print the letter
hope this helps
Garey
Nov 13, 2010 | HP DeskJet 932c InkJet Printer
All of a sudden my hp 932c printer started printing funny in color. I was printing pictures and the prints came out like a heat resolution type picture. I then got new ink cartridges, it did not fix the...
quite often inkjet heads will dry up and clog. try a clean heads sequence in the printer properties panel. do this until it prints the clean nozzle page properly. If the ink cartridges have the print head attached to them (some dont) you can dab them on a paper towel with windex or vinegar until they show a nice clean line when dabbed. if you cant get the print heads out , then you just need to continue running the clean nozzel application until it prints the test nozzel job properly. This is the reason I will not buy any more inkjet printers. only Toner based machines. cheers.
Aug 25, 2010 | HP DeskJet 932c InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
On my HP 932c Deskjet (2 actually) a metal piece behind the black ink cartridge popped out when changing cartridges. I have lost the metal piece, and need to know how to replace them. Who can I buy them...
1. this piece is probably a retainer.
2. It requires that you disassemble the print head and that require you to have the service manual. This will require proper tools to remove and replace the print head. If you damage the print head it will require full service.
Apr 20, 2010 | HP DeskJet 932c InkJet Printer
Ink light won't go out
It was a problem with the black ink cartridge. I changed it and the printer is working fine.
Oct 05, 2009 | HP DeskJet 932c InkJet Printer
I thought I was out of black ink, so I replaced the #45 black ink cartridge in my DeskJet 932C printer and it still won't print in black ink.
check the printhead especially the black partition and see if the nostril on the printhead are not damage. does the ink lid blinking if yes clean or replaced the cartridge
Aug 30, 2009 | HP DeskJet 932c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
432 people viewed this question
Seeker5211
Seeker5211
