Question about Kenmore 30 in. 42474 / 42475 / 42479 Electric Cooktop
Problem in kenmore cooking range
One of burner is not working, light is on but not heating at the coil at all
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Won't heat all settings
Locked cook-top? Check breaker, fuses, plug
Jan 03, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
How do you stop the gas cook top lightter from clicking
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Aug 11, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Burners do not light consistently
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | Whirlpool GLT3034 Gas Cooktop
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Feb 18, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
On Light Won't go off on cooktop
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Jan 29, 2008 | Cooktops
Kenmore 30 in. 42474 / 42475 / 42479 Electric Cooktop Logo
103 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
 Fix Your Board
Fix Your Board
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
