Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Starting & getting the triller to run
I can get the triller started,but when i engage the tines i t dies.then haveto restart and start it again what is the solution here? Everytime i accelerate to engage the tines, it dies
If you leave the choke on 1 (wide open to air) does it engage? If you are careful, you can remove the Air Filter and try pulling it over. This will provide adequate Air to the Gas mix and allow the engine to run. ** MAKE SURE there is NO dirt near the filter housing or you will **** dirt into the carb. If this works, you have a speck of dirt in the carb....... THIS IS ONLY TO TEST, do not use this in the garden or you will **** in dirt.
Posted on Jun 03, 2009
Have a sears craftsman 6.0 rear tine tiller.
Hi little,
The 7.0 hp version does the same thing.
I found that it was caused by the transmission not being fully engaged to a particular setting. when it tries to engage the tines in both forward and reverse, the engine stalls immediately.
After taking to neutral and back a few dozen times I got a 'feel' for it. Has happened in over a year.
Try it. It did take patience.
Best regards
Jul 16, 2010 | Craftsman Rear Mount Tiller
Tiller starts easily but cuts out when engaging tines - 3.75 HP
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. If the carb. has a foat, then you can use the Den tek Brush on the jet as well. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 13, 2009 | Troy-Bilt Garden
Tines won't turn
Possible broken key where crankshaft meets gearbox.
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
259 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
