Question about Garden
Steering Adjustment for a Dixon ZTR
The left level needs more motion than the right, making it difficult to stay stright without the left lever being several inches farther forward than the right
  • Anonymous Mar 21, 2014
    where can I get one
    President:
  • 2,559 Answers
Try the 3310 as pictured below
Posted on May 31, 2009
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Why does my vehicle make a jerking motion and a squealing sound when I turn the steering wheel all the way to the right or to the left?
It sounds as though the CV joint(s) on the steering--a sort of universal joint--may be failing. I really would not chance it further without professional advice.
Jan 23, 2015 | Cars & Trucks
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
Why Dixon lawnmower goes slow?
Yes they should be a sealed system. Check the fluid level in the tank.
Sep 16, 2017 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
My 12 year old Dixon ZTR mower turns to the right only slowly. Left turning is normal. The right steering lever has to be held farther forward than the left one to go in a straight line. Repair shop...
Hi, first check your tire pressures are equal then check/replace wheel drive belts and pulleys for uneven wear. If all ok adjust the drive link arms until it travels straight. Regards Phil.
Jun 14, 2012 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Dixon ztr 311 The left lever will not make the mower go forward and the right will not make it go back. Any ideas?
The motion drive design is similar to a set of spider gears, except it uses friction material rather than bevel gears in the cluster. The friction material may be worn down to the point that it no longer engages and needs replacement. This is a likely scenario for the symptoms you describe.
The replacement procedure is a rather involved process. If you feel confident and are VERY handy, reply to this post and I'll be happy to go into detail.
Hope this helps!
Oct 01, 2009 | Garden
Garden Logo
2,261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
