Question about KDS Radius RAD-7 17" Flat Panel LCD Monitor
Computer monitor doesn't show colors good only white and blue
Monitor starts out great but the longer I use it all colors but white and blue become fuzzy with what looks like lines in the picture.
  • 674 Answers
Drivers not installed properlyu...install properly the driver, if then same proble check the VGA card for the desktop/ vga chepset chep in laptop.. or cable connection og vga...
Posted on May 31, 2009
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
Tip
Mitsubishi 3.0L V-6 engine flooding and will not start. SOLUTION
Recently, I have been struggling with this 2004 Dodge Stratus Coupe, R/T, with the 3.0L Mitsubishi V-6. Flooding and will not start. Timing belt was on the mark, crankshaft position sensor was showing RPM on the scanner, it was showing spark on the spark plugs, and had great compression and flooded cylinders. It was difficult. HOWEVER, the spark was a WHITE color. It ended up being a WEAK COIL. It is located in the distributor. I replaced the entire distributor with one from AM Autoparts off of eBay. Started right up and runs great. I want everyone to know that just because it had spark, doesn't mean that it was good spark. The COIL WAS BAD. I wanted everyone to know what I finally found. Thanks to everyone who pointed me in the right direction. This includes my fianc? Carmella. She stated that the spark was WHITE, not HOT (orange or blue).
on Jan 15, 2018 | 2004 Mitsubishi Eclipse
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
My sceptre X22WG is no longer showing white screen but getting progressively darker blue. How can I get it back to a white screen?
Colour changes like this are either due to a failing graphics card, failing monitor or bad connection from the computer to the monitor.. with this monitor, I'd have it checked by a tv repairman
Jan 18, 2011 | Sceptre x22wg Gamer Monitor
MY LG 500G CRT 14" monitor is become faded and very white color graphics(nothing seen with out white color) after 1 or 2 sec. when i re start the monitor i can see some very brigh graphics then again...
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
Mar 29, 2010 | LG Studioworks 775N 17" CRT Monitor
When turn on color is great..after a few minutes turn blue and green
Sounds like the lcd is bad but here is a way to verify that. Hook up a known working monitor to the computer, if the colors stay great after a few minutes then you know the original monitor is good.
If the colors turn blue and green after a few minutes with the working monitor then you know for sure that the video card is bad and the video card would need to be replaced.
Aug 23, 2009 | Vision V1721B (Black) 17 inch LCD Monitor
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
KDS Radius RAD-7 17" Flat Panel LCD Monitor Logo
184 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
