Question about Mitsubishi WS-65907 65" Rear Projection Television
Convergence problem I have a Mitsubishi 65" model # WS65869 and I'm having problems with the "Red". I have tried to align the red and I can only go side to side and down but not UP. I have tried to reset the convergence to the original factory settings but it doesnt help. Is there a way for me to correct this problem without the call of a serviceman?
  • 1,959 Answers
You will either need to order a new convergence board or a STK chip to replace the bad one. STK chips require using a soldering iron. A handy guide for this repair can be found by clicking on the link below. Best of luck and hope this answers your question.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on May 31, 2009
Projection TV Convergence problem
go to the Mitsubishi service center to solve your problem
Jun 20, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi 65 in has greenish blue coloring mainly at bottom of screen any idea's?
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 06, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
65" rear pro. Convergence IC Repair
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Blue arc extends acoss width of mitsubishi ws65869
The WS65869 is a CRT based projector, no bulb. It sounds like you have a convergence failure. The convergence output ic's will need replacing.
Jan 02, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red convergence problem - Mitsubishi 65
It sounds like your red gun might be close to going, we had the same problem our tv. The red was off and couldnt really be adjusted but the others were alright. We were told that the red gun was nearing the end of its life and it could cost upwards of $1000 to fix, so we just got a new tv. i would suggest having a tv tech come out and look just to make sure, but thats wut it sounds like.
Oct 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red arching lines
is this that you are adjusting called convergence? If so then if it's really bad you can try to reset convergence, if not then the red needs to be aligned up with green first then blue on green. Can you provide a picture of what it looks like?
Apr 13, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
222 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
