Question about Dell 1125 All-In-One Laser Printer
Dell laser printer MFP 1125 paper tray removal
How to remove the protruded plastic paper tray houseing out for shipping.
Seemingly needed to press certain catches somewhere to unknock the tray assembly to remove it. But where and how?
Thanks in advance.
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
Posted on Jun 27, 2009
  • ozmodem Jan 13, 2011
    To remove the paper tray. There is a light blue curved button on the front of the tray, pull back on it and pull tray out walla.
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
Dell Mono Laser MFP 1125 says no toner found invalid toner it just flashes the above i just added a new cartridge
double check the one you installed to ensure it was installed correctly. You can do this by removing it with the power turned off then reinstall it. Try to power it back on.
Spanish speaking available for all problems Thank you for allowing us to help, please respond with further questions and concerns
Jan 09, 2011 | Dell 1125 All-In-One Laser Printer
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
I can not receive faxes on my Dell MFP 1125
Hi, I have Dell 1125 All-in-One Laser Printer. I can send faxes by going to fax option and dialing the number.
How can I set it up to receive faxes? keep in mind that I have only one phone line which I use for both phone and fax.
How can I set the ringers in a way that for example at 4th ring goes to answering machine and at 6th ring goes to fax?
I really appreciate it.
Need help fast :)
Mary
Aug 03, 2010 | Dell 1125 All-In-One Laser Printer
The printer is asking to load legal paper in Tray 1 but legal paper does not fit in Tray 1. How can I redirect it to mfp?
Paper up tp 14" long will fit in the paper tray.
Remove the paper tray fully from the printer.
You'll see a blue tab at the rear edge of the tray, this releases the adjustment of the length of the paper tray. Adjust to the size you need, and replace the paper tray.
NOTE when new (and in the box), the printer has tape on the paper cover (at the back of the printer), make sure this has been removed, as it will prevent the paper tray being pushed fully 'home' when adjusted to a large paper size.
If you print a lot on both A4 and Legal size, maybe it would be worth buying a second paper tray and leaving them set for the different sizes you use.
May 21, 2010 | Dell 3110cn Laser Printer
Where are papertray release taps located in the "Dell Laser printer MFP1125" ? (in order to take the paper tray out for shipping.)
For the upper paper lip, just lift it up (rotate upwards), and pull towards you to remove.
As for the lower paper tray, remove the cover (it should come off easily), and use a flat screwdriver to pry the two round light-grey colored tab on the inside inboard to release the drawer. It takes some fiddling around to get it loose, but it does come loose... Just be careful since those tabs are very brittle and can snap easily.
Best bet is to use the original box for safe transportation, that way you won't need to remove the tray...
Jun 29, 2009 | Dell 1125 All-In-One Laser Printer
Paper is torn at fuser area of Dell 1125 and cannot remove
Please double check if all doors, including the paper tray cover, are firmly (repeat FIRMLY !) closed. Seemingly all such are designed as precautionary measures for safe operation.
Mar 08, 2009 | Dell 1125 All-In-One Laser Printer
Fuser paper jam on Dell mono laser mfp 1125
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Jan 28, 2009 | Office Equipment & Supplies
Dell 1320c printing error "no paper detected"
I had the same problem. I removed the paper tray, turned the printer on its side and manually moved all the working parts on the bottom of the printer - rollers and switches..
When I reinserted the paper tray, everything worked fine.
PS. I ordered and returned a new paper tray from Dell, that was not the problem.
Jan 09, 2009 | Dell 1320c Laser Printer
Dell 1125 All-In-One Laser Printer Logo
973 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
