Question about Pentair Minimax NT Heater
Pool heater can it damage a pool heater if you do not let it cool down properly heater is 5years old.
    Champion:
  • 246 Answers
Yes and no, the heater will not get damage can handle hot water, buttttt... the pipes and the filter made of cheaper plastics may get damage slowly
Posted on Dec 11, 2014
    President:
  • Pentair Master
  • 1,378 Answers
No, though you sort of waste the gas running the heater all the way to the point you shut down the pump.
Posted on Jun 12, 2009
How does water flow affect Harwood H100 pool heater
if you dont have enough flow, the heater wont run. if you have a VS pump and run it at minimum speed to let heater work, the heater wont cool properly and may damage components.
Jun 27, 2014 | Hayward H Series Induced Draft Abg 100,000...
I have a Laars LX250 pool heater. The pump and heater are tied in with a timer that has a fireman switch. When operating properly the switch disables the heater for cool down before the pump shuts off. I...
If this answer does not fix your problem, pleasecomment with additional details prior to rating the answer. Positive feedbackis appreciated once your problem is solved! Thank you.
Aug 17, 2011 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
My Haywood H250FDP heater fires up for a few seconds and goes out. After several tries I get a Low gas pressure/No gas error code. I had my propane suppier come out and check. He tried to adjust the...
the flame sensor/thermo couple can be bad and or needs cleaning --carbon build up [one day old -one year old- 20 yrs old defective or damaged parts can happen any time]
Jul 04, 2011 | Hayward H-series Electronic Gas Pool...
On my all buttom qualink 4 on my buttons work except when I turn the spa off the cool down mode doesn't seem to work it says heater will turn off after cool down but the jandy doesn't turn back to filter...
Your heater should shut down rite away and the pump will keep running to pump cool water through the heater. After the cool down period then the valves will go back to normal run positions.
Nov 04, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Should the pentair minimax pool heater be wired to line or load?
Thank you for posting your question here on Fixya.com.
Line side for a couple of reasons: First, there are more safety switches than just the pressure switch to ensure the unit shuts off prior to damaging itself. Second, and probably more importantly, removing power from the unit each time the time clock turns it off will keep erasing the temperature settings you enter. After a while that gets old for most people. Coincidentally, when pressure switched fail, they fail as open making the heater inoperable. While they could conceivably short closed and cause the situation you fear, I have never seen that in 20 years of servicing heaters.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 09, 2010 | Pentair Minimax NT Heater
Whisperflo Pump 1.5 Hp problem
The pump is probably fine the motor is the problem. If it just hums it might just be the capacitor on top of the motor. Don't know how long it sat there not able to start. Was the motor extremely hot ? If it got too hot may have damaged the motor. Motor is replaceable without replacing the pump head.
Sep 30, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
I have a Kenmore Refridgerator appx 5years old, everything runs properly but does not get cold. It also runs all the time.
is the freezer at temp, meaning is everything in the freezer frozen? if so, it sounds like you have a defrost problem. is there heavy frost and ice one the back wall of the freezer? if so its a defrost problem. bad defrost thermostat, timer, or heater
Jan 02, 2009 | Refrigerators
Pentair Minimax NT Heater Logo
133 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
