Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Panasonic dmr-ex95v - dead machine
My DVD recorder has died. I have checked the internal fuse, which is ok, and the fan runs when the power cord is attached, but there is no display or anything! Also, there is a video cassette stuck in the machine, and I can't see a simple way to release it manually. Any help would be greatly appreciated.
Anthony
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
  • 60 Answers
SOURCE: none of the buttons on the remote will work!!! dmr ex95v
Try unplugging the dvd player for 30 seconds. Try to turn unit on a couple of times without power (discharges capacitors). Plug it back up and see if that works. It's a shot in the dark, but worth trying.
Is the remote the original remote for the unit? Could try reprogramming for dvd player if it's a universal remote.
Posted on Apr 06, 2009
nandosnut
  • 112 Answers
SOURCE: Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
Posted on Apr 18, 2009
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Posted on May 28, 2009
I have a Panasonic DVD Video Recorder model DMR-E85H manufactured in 2004. It has worked perfectly for all these years but now won't power up at all. I have checked the only fuse I could find inside...
The power supply board is the problem, one of the most common failure is the 1000uf capacitor "open" located near the power transistor that is heat sinked, value may be higher or lower with one or two caps, the second possibility is the power transistor may be open or shorted.
Jun 24, 2011 | Panasonic DMR-E85H DVD Recorder
I have a Panasonic DVD Recorder DMR-ES10 that will not power up. Are their any fuses on this unit?
hi,
every electronic equipments comes with fuse in the input side for protection .ur dvds power supply may have some problem. check it before inserting the fuse.
ok
Dec 17, 2010 | Panasonic DMR-ES10 DVD Recorder
Power supplierd but does not start recorder no
Hello:
If the unit is competely dead, then you may of blown a fuse or the power supply has failed in the unit. If you take off the top of the unit while unpluged check the fuses near where the power cord attaches to the inside of the unit this is the power supply area, If you have indicators lit or the display is coming on then the unit may have a bad power supply or the System control board has failed. It which case its cheaper to just purchase a new unit.
Jul 14, 2010 | Panasonic DMR-E85H DVD Recorder
My dvd player is dead.
You check the SMPS (Power Supply Section) and verify the voltages from the various terminals of the transformer accordingly check the bridge, voltage regulator, and filter circuits. If any of this parts are gone replace the appropriate parts not the all.
Jul 25, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
None of the buttons on the remote will work!!! dmr ex95v
Apr 06, 2009 | Panasonic Televison & Video
Panasonic DMR-E50 no power
Check the two pin power plug on the back panel.
These units have a common problem on the power board where a regulator overheats and finally blows. Sometimes even before it blows it will take out an internal fuse. If the power board is faulty the repair is easy for an engineer and not too expensive.
Mar 19, 2008 | Panasonic DMR-E50 DVD Recorder
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
No power to anything even display on Panasonic DVD Recorder DMR ES10
Try unplugging the AC cord from the back of the machine& your power strip for 1 minute and plug in again. I had the same problem,(the clock was working, so I didn't think it was that but it was). Must have had a glitch in the cord and needed to reset,
Nov 20, 2007 | Televison & Video
Power problem
yes it is worth repairing take it to a tech the problem is in the power supply,goodluck.
Mar 29, 2007 | Panasonic DMR-ES30VEBS
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
