Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi vs-50605 rolling lines started when tv first turned on and would go away when warm now problem will not stop, looked for convergence ic's could not find, not a tv person but experienced in auto electronics, could repair with good information.
  • 2 more comments
  • stennis Nov 03, 2007
    when turn on horizontal lines and ziggling. Use to get better after TV had been on for a while, but now lines there all the time, except when we play a dvd movie, so only happens when we use the TV.
    Any ideas
  • Anonymous Nov 25, 2007
    I have the lines fluttering on this same model - they sporadically go away after the tv has been on for a while. I have the lines without any type of input (cable, DVD, etc.), so the problem is not with input.
  • golfadict Dec 14, 2007
    tvray called it, I had my tv repaired and the repair man replaced 4 small capacitors, tv good so far, he had a special tool to check capacitors while still on the board, cost 241 plus the 95$ service call, he charge about 9 dollars a capacitor.
  • Anonymous Dec 31, 2007
    I have the same problem, when I first turn on the tv it has the rolling picture, then after about 20 minutes or so it'll go away. I have not tried any steps to correct it but I've called the only two tv repair people in town and one guy told me he doesn't work on mitsubishi's and the other repair place does not answer, so I'm hoping that you will help me with this problem. I would appreciate some help. Thank you so much.
  • 3 Answers
I found the STK392-110 on http://www.electronix.com/ be careful how you solder and always make sure you didn't bridge the pins with solder.
Posted on Jan 01, 2008
I had the same problem and I fixed it by changing both convergence ICs. IC number STK392-110. There's also one more problem that I have to look in to and it has to do with the reception on the TV. All I get is static even after I did a channel scan.
I read on one the solutions would be to replace the capacitors. (the rolling tv problem). So where are the capacitors in the tv and where can I order new ones? Thanks a bunch.
Posted on Dec 31, 2007
Mine is doing the same thing where and whats parts do I need to get?
Posted on Dec 10, 2007
  • 59 Answers
Does not sound like convergence have had a few with bad capacitors. any good at soldering
Posted on Oct 23, 2007
I have a mitsubishi 65 inch model VS-60703 it does turn on but the screen dark.What could be posible wrong with it?
Posted on Feb 16, 2009
Mitsubishi Vs-60705 Bigscreen turn on vertical roll warms up stops rolling and begins jumping up and down also picture is not clear
Check C2P05[ location on convergence board]. This is a 16volt 100Mf cap that is bad. And check out C2V29 [cap value is 16volt 22 Mf.] And still while you're at it, resolder the pins on the convergence ICs.Should fix your TV!
Nov 29, 2009 | Televison & Video
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Rolling lines until tv warms up
Vertical output IC bad capacitors in vertical circuit 100uf 35v sometimes vertical IC needs to be resolder and that fixes problem look for poor solder joint s.
Sep 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv problem
bias on green is too high or current is too high^^^turn bias down on focus block^^^--curved lines(not retrace lines) convergance IC`s going or resistor(s) out of range^^^replace them^^^
Sep 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-5006R picture Ghosting
Since the problem corrected itself initially, it may just be poor solder connections. Try resoldering the pins on the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If resoldering does not resolve the problem, replace the ICs.
Dan
Jun 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv problem
replace both convergence ICs STK392-110 they are available at the following link and they give free installation instructions and free online tech support. The repair is easy and takes about 45 minutes from start to finish.
http://servicemanuals.vstore.ca/
Mar 05, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Lines through picture
this unit needs new convergence ics.It should run about 250 for repair from a honest tv repair shop.
Mar 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
269 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
