Question about Brother XL-5500 Mechanical Sewing Machine
Sewing machine XL 5500 settings
I need a diagram how to thread my brother sewing machine XL 5500, and also need settings for the tension. The tread balls up under the underside of the fabric and it doesnt move. How should the feeder plate be set?
please help
debra
Your bobbin is probably too loose. When you set a new bobbin, stop every now and then and try with your fingers nail if it's nice and tight enough. Not extremely tight, but tight, not loose and moves easily when you set your finger between the threads.
With most fabrics (99%) the plate is fine at the the top position, just with very thick and "fragile" (satins etc) you might need to adjust it.
Settings: Tightest tension for the thinnest materials, more loose for the thicker ones, better have a test piece, it rarely goes under 5 anyway.
Posted on Aug 25, 2009
  • Brother Master
  • 11,749 Answers
Remove the top thread from your machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and then rethread the top thread--verify the thread path is correct.
Set the top tension to the midway point (starting tension setting but may need to be tweaked for your particular machine).
HINT; thread problems appearing under the fabric are usually related to a top thread issue. Thread problems appearing on the top of the fabric are usually bobbin related.
What you are experiencing is called bird nests/thread nests, or what I refer to as thread barfs. The most common fault is the top thread is not seated in the tension disk. Raising the presser foot while threading will allow the thread to seat properly.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Posted on May 15, 2017
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
The tread under my fabric is loose and slack when I sew with my brothers LX3125 sewing machine please help
increase top thread tension a little, make sure that the top thread is between tension discs.
Oct 27, 2015 | Brother LX3125 Sewing Machine
I have a brother xl 5500 it keeps breaking the top thread no matter what i do
Go back to your instruction manual, some available online. to Re-thread the machine completely and make sure you are threading correctly. If that's not it, you may have thread jammed in a mechanism and it needs a technician's tools to get at it properly.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother XL-5500 Mechanical Sewing Machine
The tread is breaking while sewing with brother ls 2125
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
The stitch tensioner doesn't seem to be working. On the highest setting it is still looping on the bottom side.
Make sure the machine is properly threaded.
The thread must go thru the tension discs and under the spring before going up to the arm that moves up and down.
If this looks OK then pull on the thread when the needle is in it's lowest position. If you don't feel resistance, then the tensioner needs to be adjusted.
This is done by loosening the screw that keeps the tensioner from rotating, and rotating it. You have to do this in away that allows the spring to move freely in the slot that captures it.
- You may want to bring it in to a shop instead.
Oct 18, 2010 | Brother XL-5500 Mechanical Sewing Machine
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
My four-year-old XL3500 seems to have a tension problem. It was sewing fine until after I refilled the bobbin, changed thread twice, and did some zigzag stitching. Now the top stitch is not correct; it...
according to the diagram in the manual, the upper thread tension is set by the wheel/knob on top and just to the right of the thread take up lever and thread guide. If you don't have a manual, go to www.brother-usa.com they have a downloadable manual for your machine.
Jun 04, 2009 | Brother XL-3500
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
What should I try next?
I AM NOT SURE BUT TRY TO ADJ. THE TENSION OWN THE BOBBIN
May 29, 2007 | Brother XL-5500 Mechanical Sewing Machine
Brother XL-5500 Mechanical Sewing Machine Logo
525 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
