Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Can't reconnect drain stub to nipple (MDB6100AWG)
My MDB6100AWB Maytag d/w drain hose stub slipped off the motor drain nipple - probably because of all the plunging I did in the kitchen sink when had a bad clog. I can't get it back on securely from underneath. For this model do I have to remove the d/w and turn it on it's back in order to get that 3" black connector securely on the drain nipple? Or am I missing something here?
    Problem Solver:
  • 5 Answers
Your not missing anything, the easiest way is just that, pull out the machine and save your forearm and about an hour of trying the hard way.
Posted on Jun 01, 2009
  • ericjansen14 Jun 01, 2009
Maytag dishwasher MDB6100AWB
None of lights or bottom do anything on the front panel of the model mdb6100awb.
Anybody got a answer for this.
May 27, 2012 | Maytag 24 in. MDB6600A Jetclean II...
I have a Maytag Bravo Washing machine, and am having trouble with the drain cycle. I have replaced the pump twice and have checked the drain line. My washer will start and get to the drain cycle and it...
Here are some pointers to look at to determine the real problem. The code Ld indicates that the water level does not change after the drain pump is turned on.The machine/motor control detects such condition through the water level pressure sensor located in the control itself.
Since the drain pump is definitely not the problem, either the drain hose is blocked or installed too high, or the pressure sensor system is malfunctioning. Check if water is actually draining or not. If yes and the tub is actually empty when code appears, then the problem is in pressure sensor system. If no, then check for drain blockage.
Unplug the machine. Remove the three screws from the rear of the console assembly then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub. Also disconnect the pressure hose from the machine/motor control and blow air forcefully down the hose and also into the pressure sensor inlet in the control.
Replace the machine/motor control assembly if and only if verified that there are no issues with the pressure sensor system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses.
NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Labeling the connections makes reconnection more easily and trouble-free.
Jul 15, 2011 | Maytag Washing Machines
Where is the oil drain line at the front or the back?
Harley Davidson
Sportster = At the back, oil tank drain hose connected to a nipple on the frame with a hose clamp.
Twin Cam = Under the motor you'll see 2 plugs, one vertical and one horizontal.
the vertical bolt is the oil drain plug. The horizontal bolt is the Transmission drain screw.
Evo = Back of the bike, oil tank drain hose connected to a nipple on the frame with a hose clamp.
Some may be modified and just be a hose with a bolt stuck in it with a hose clamp.
Dec 01, 2010 | Harley Davidson FXST Softail Standard...
Maytag neptune front load washing machine will not fully discharge water after the rinse cycle...HELP???
Check the drain hose and clear it from any debris that might be blocking the water from draining out completely. If the drain hose is clear of debris, check and clean the pump. Disconnect the machine from the power outlet before servicing for safety purposes.
Remove the rear access panel to access the pump and disconnect the wiring harness from the terminals of the drain pump and the pressure switch.
Loosen the clamps holding the drain hose and the tub hose to the pump assembly. It is a good idea to spread a towel under the pump before loosening the clamps.
Remove the hoses and rotate the pump assembly counterclockwise to release the pump assembly support legs from the keyed slot in the base of the washer. Remove the pump assembly from the washer.
Clear the pump impeller from any debris that might be causing it to work improperly. Clean the tub and the drain hose.
Reassemble the pump, the hoses, and reconnect the wires to the terminals of the pressure switch and the drain pump. Reinstall the rear access panel and run the machine.
Replace the pump (part #25001052) if water still do not drain out completely.
Remove the plastic bag covering the pressure switch. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
Grasp the pressure switch and lift the nipple of the pressure switch from the pump cap.
Install the pressure switch into the new pump assembly in reverse of the steps above.
Feb 24, 2010 | Maytag Neptune MAH6500A Front Load Washer
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer wont drain hose ok model La105
Good day,
Remove front panel, 2 screws on bottom, lift bottom away and pull out.
Check to see if pump belt is broken, or extremely loose.
If loose, see if motor glide springs are free and pulling back on motor.
Reach under, and turn pulley of pump to see if it is free.
If it will not move. Stop.
Pull off pump to tube hose. Remove other hose on pump and remove.
Remove pump.
This machine is a known sock eater. Check hoses and pump, and if found clear.
Feel up in tube nipple for same.
If nothing, replace pump, or belts as needed.
Note: belts should be replaced as a a pair. Reinstall the pump, and adjust as necessary.
Thank you for using Fixya
Dec 22, 2009 | Maytag Washing Machines
How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Dec 13, 2009 | Siemens Dishwashers
Maytag mdb6100awb trips circiut breaker after 5-10 minutes in use
The first thing I would do is install a new circuit breaker. That could well be your problem.
Jun 18, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Broke plastic nipple on heater core 1996 dodge neon
You will have to replace the heater core, Only one thing other than that, if there is enough of the nipple sticking out you may be able to clamp the hose onto the stub.
Sep 05, 2008 | Dodge Neon Cars & Trucks
DISHWASHER WILL NOT DRAIN
The machine is held in the cabinet with several screws that go up into the front edge of the cabinet. Open the door to find the screws. Lift up on the washer cabinet slightly to avoid harming the kitchen floor when pulling the machine out. Try pulling the hose connection at the sink drain stub and using a wet/dry vacuum, **** the end of the hose and the drain stub. With luck, the clog will be pulled out. Good luck!
May 05, 2008 | Maytag MDB3100 Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
66 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
