SOURCE: 900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
SOURCE: 900 Service RIP Software
Are there any memory or Barcode SIMM's in the printer? If so, remove them (power off first!) and turn the printer back on and see if it acts normally. I have had 1 instance where the Barcode SIMM has caused that error. The Barcode SIMM had to be replaced. Most other times the 900 RIP error occured, a simple turn off/on "fixed" it (sometimes only temporarily). If all that doesn't help, flash the engine code with the latest from Lexmark support. If that doesn't do it, then engine and/or controller card need replacing.
SOURCE: Message saying 900 Service RIP Software.
try reseating the memory card on the rip board first...i know it sounds weird but just try it
SOURCE: What does 900 Service RIP Software error message
If the 900 error occurs
only when the printer is receiving information from a network or
computer, contact your software/network support. If the error occurs
when the printer is idle or not connected to the network or PC, there
may be a printer hardware or connection problem. Sometimes a bad
connection with an Internal Network Adapter/Network Card can cause the
problem. The first thing to check is the base printer.
To
check the base printer:
IMPORTANT: If
you receive an Invalid Engine
Code error message when you power the printer back on,
there is a problem with the printer. An Invalid Engine Code condition
will cause a 900
RIP Software Error message to appear if you try to use
the printer. The Invalid
Engine Code error means either that your printer has
lost its stored operating code for the engine board or that the
printer's engine board has gone out.
Optra
S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
Optra T
and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
